Cable management question
By
Gusto
in Cases and Mods
in Cases and Mods
Solved by NineEyeRon,
Back in the day we just zip tied and taped to the case metal where it was possible. Just aim to move the cables out of the middle, away from heat sinks and fans etc.
Difficulty: Low
Cost: Some (zip ties, anchor points optional, tape optional.)
Time: 30 minutes should be enough.
kasdashd ·
1
6
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
