RAW drive, among other problems
Go to solution Solved by 191x7,
1 hour ago, AntiHero said:
can confirm corruption was found, rebooting rerunning as it told me too
Let us know how it goes.
So i uninstalled some stuff namely battle net and blizz games (really dont wanna get into politics right now just need help). i turn my laptop back on, it right away begins to repair the D drive my HDD, when it finishes and finally boots i appear to be locked out of everything on the C drive my SSD and my D drives comes back as RAW, cant check disk (obviously) but can't partition either and its says when i try to interact with it i have specified a drive that doesn't exist. i can still see all the files that are there i just cant get to them, the one on the C drive that is and my desktop is blank save the recycling bin, i was however still able to get into bitdefender and run a full scan for whats its worth, came back clean, but it also clearly missed alot of shit and as predicted didnt even notice a D drive, which by the way still shows up under disk management, just again, RAW. I am totally stumped and really concerned, please help...
https://linustechtips.com/topic/1112345-raw-drive-among-other-problems/
Could be a software bug. Could also be drive failure. Try disconnecting this D:/ storage disk and reconnecting it. May start behaving again.
im afraid to crack this thing open but i didnt spend all that time or money on training to bitch out now....
Should be easy. Connected disks are usually made pretty easily user accessible for installing/uninstalling.
What I'm looking to have you test here is:
  1. Remove the HDD (D:/ drive)
  2. Start the computer. Let it recognize D:/ is no longer there.
  3. Shutdown
  4. Reconnect D:/
  5. Turn laptop back on.
If it still appears as RAW connect the drive to a different computer. If it's still RAW the drive could be dead/failing or something on the laptop could have corrupted it.
11 minutes ago, AntiHero said:
gotcha the other thing i worry about is why am i locked outa everything else, like wtf happened? both drives, no way... concerns me
From my experience this can occur when the system loses connection with the storage device. Be it a bad SATA cable or bad controller. So for example if you were to restart the laptop and it said "No bootable device found" that'd confirm that theory.
can confirm the D drive is deff shot, however C is still locked and i seem to be having issue getting into my bois now as well -_- gonna go right to the end game and try to reinstall windows
20 minutes ago, AntiHero said:
ah ok, going in for it now, see how it works
Run this batch script to fix Windows:
Run Hard Disk Sentinel to read the data about the health of the drives. Let us know what Sentinel says.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
@AntiHerothe script needs to be run as admin (right click on it and run as administrator).
Sentinel says the RAW disk is healthy?
did run as admin, just didnt see i had to keep advancing it, sorry have abit going on over here. and no the disk is totally bricked, its an HDD i wrote it off at this point i can just replace it, now my concern is why is my SSD acting up and locking me outa shit and telling me to contact an admin
I recommended the script because your Windows might be broken.
Drive repaired all is well, my HDD storage drive is a paper weight now but the OS and C drive are back to normal, thanks!
You could be able to "repair" the HDD just enough to copy the data
Step 1: Connect the RAW hard drive to your PC.
Step 2: Click Start button and search "commond", then right-click one it and afterward press Run As Administrator.
Step 3: Type in Diskpart and then press Enter.
Step 4: Type partition_letter: /FS :NTFS and press the Enter key.
** partition_letter for example D or E, F, ...
This would have changed your RAW drive into NTFS file system and the data you have stored in it can be used again.
Well fortunately theres nothing in there important that I didnt have backups of, the rest is all game data I can redownload. I dont wanna fight with it anymore, already have a new drive shoved in there. But! I will definitely keep this information set aside for future use, very helpful, thanks again!
this changed but it still isnt showing up
