Hi, I'm looking for a new case. Right now I have the 750D and I'm not a fan of it. It's super flimsy and the cooling isn't that great. I'm using a TR4 motherboard so I'm looking at E-atx cases. Just from googling it seems like the cosmos c700m is good but the be quit dark base pro 900 r2 is better? Oh and if it has decent fan filters it would be a huge plus cause I have two animals that shed like crazy. Anyone else have other recommendations please? Thanks!
https://linustechtips.com/topic/1111879-case-recommendation/
What motherboard is it exactly? Location? I'd ask budget but since you're looking at a C700M I imagine it's ludicrously high.聽
RGB Build Post 2019--- Rainbow 馃 2020---Velka 5 V2.0 Build 2021
Purple Build Post ---Blue Build Post---Blue Build Post 2018---Project ITNOS
CPUAMDR7 7800X3D聽 聽聽MotherboardAsrock B650E Taichi Lite聽 聽聽RAMCorsair Vengeance RGB 32GB 5200mhz聽聽 聽GPUASUS RTX4080 STRIX聽
CaseFractal Torrent聽 聽StorageSamsung 980Pro 2TB, Crucial P3 Plus 4TB x2,聽 聽 聽PSUCorsair RM1000x聽 聽聽CoolingDeepcool AK620
https://linustechtips.com/topic/1111879-case-recommendation/#findComment-12952590
