I built a computer and everything was fine until i installed my graphics card and my audio stopped working. I have received help from tech support from all the companies that made my parts but none of the things they told me to do helped. Another problem I've received is that when i try to reset my computer it gives me the error "There was a problem resetting your pc. No changes were made." I'm not sure if these problems are related but it makes me think that my motherboard might be screwed up.  If anyone has any ideas that could help me with this problem that would be awesome.
Part list:
Motherboard: ASUS Prime B450M-A
Graphics card: Gigabyte Radeon RX 570 Gaming 4GB
CPU: AMD Ryzen 2200G
SSD: Samsung 860 evo 1tb
RAM: V-Color SKYWALKER PRISM (2x8)
https://linustechtips.com/topic/1110935-audio-problem-windows-10/
Part list:
Have you installed the GPU drivers? As for not being able to reset the PC, try with the cmd command to check system file integrity
sfc /scannow
DESKTOP PC - CPU-Z VALIDi5 4690K @ 4.70 GHz | 47 X 100.2 MHz | ASUS Z97 Pro Gamer | Enermax Liqmax II 240mm | EVGA GTX 1070Ti OC'd
HOME SERVER | HP ProLiant DL380 G7 | 2x Intel Xeon X5650 | 36GB DDR3 RDIMM | 5x 4TB LFF Seagate Constellation 7.2K | Curcial MX500 250GB | Ubuntu Server 20.04
