HELP!!! I notice that when my computer is in high load, when i open a lot of tabs of google chrome or while i'm playing a game like BF4, I'm getting power leak, I can feel electric tingling or sometimes a sharp pain when i touch the keyboard, I tried touching the screws that lock the tempered glass to the case even the screws have the electric tingling feel. Would it be a faulty motherboard or faulty psu? HEEEEELP
https://linustechtips.com/topic/1110471-help-power-leaking/
Is your power outlet grounded?
https://linustechtips.com/topic/1110471-help-power-leaking/#findComment-12940568
are you sure its grounded?
do you have a ohm meter to test. https://mrelectric.com/blog/how-to-use-a-multimeter-to-test-an-outlet
what psu do you have?
can we get your config and a photo of the case.
it doesn't matter what your doing and the only electricity on your keyboard is 5v and maybe a static low volt electricity.
https://linustechtips.com/topic/1110471-help-power-leaking/#findComment-12940575
Motherboard standoffs installed?
Check the rear IO ports where your keyboard is plugged in and make sure the IO shield isn't bent in to the USB socket and that there isn't any other damage to the USB socket on the motherboard or the keyboard itself.
The power supply is definitely connected to a grounded wall outlet?
The power supply has a 3 pin plug and the wall outlet is actually connected to a ground line and isn't just a 3 pin socket with the ground pin unconnected? You're not using a extension cable or power strip that only has a 2 pin plug?
Try plugging the system in to a different wall socket.
https://linustechtips.com/topic/1110471-help-power-leaking/#findComment-12940577
i mean without the standoffs it would have been fried on first boot.
https://linustechtips.com/topic/1110471-help-power-leaking/#findComment-12940582
38 minutes ago, ACEHACK said:
Umm? Wrong link?
https://linustechtips.com/topic/1110471-help-power-leaking/#findComment-12940634
I've seen bad power strips causing this, especially the cheap ones.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1110471-help-power-leaking/#findComment-12940682
yes, im sure it's grounded.
my computer are rough 4-5 years old,
PSU 400W Cooler Master
Motherboard Asus H87 Plus
i5, not sure what gen
8gb Ram
GTX650 2gb
https://linustechtips.com/topic/1110471-help-power-leaking/#findComment-12940689
  • 1 month later...
