9700k temps
2 hours ago, diabloinfinnity said:at 4.9gh 1.315 v and some cores hitting 85? fans on full blast. I'm getting abit nervous. any ideas?
no workers failed yet 20mins later.
like with prime 95 my fans ramp up at some point during the test every now ad the and that's when im at 85
will cpu heavy games brig me to the same temp or would this just be prime 95
Prime95 gives stress loads that you won't really see in any other applications gaming-wise.
Normally, if you want to check the temps of your CPU you should really do stress tests. My 3700X, although a different CPU, likes to spike in temps at idle between 35 and 50 degrees Celsius, but on Prime95 small FFT tests it won't hit higher than 68 to 70 degrees Celsius and I'm completely happy with that.
If you're really worried about it you can always just re-seat your cooler with newly applied thermal paste for peace of mind? It's not a hard or time-consuming thing to do and you can feel better about your current CPU temp situation. At the moment though I don't really see anything to be worried about.
