Lian Li O11 Dynamic XL RGB Header/Terminal
Solved by TVwazhere,
20 hours ago, Mr. Red said:but both terminals have 1 pin blocked off (plastic is covering the "R" terminal). Is that normal?
Those are ARGB headers. You need to plug them into ARGB ports on your motherboard, NOT regular RGB 4 pin connectors on your motherboard.
Your motherboard does not have an ARGB header, so you will need to buy a seperate controller box to plug into like this one:https://www.asus.com/us/Motherboard-Accessories/ROG-Aura-Terminal/
