Case fans cheap
Go to solution Solved by WoodenMarker,
10 minutes ago, MrBigD1409 said:
no im not searching to fill it up with rgb i just want to have more airflow and change the front 2 too cause they are making some strange noises like breaking and want to change them too, so 1 rear and 2 in front, dont want to put others on top
If you want quieter fans, 2x NF-P14S' for front intake and 1x NF-P12 for rear exhaust would be better.
https://www.amazon.it/dp/B00KHRGWLM/?tag=pcp06-21
https://www.amazon.it/dp/B07CG2PGVG/?tag=pcp06-21
Ok guys so i was thinking on going like this.
On my rear case putting this fan(
https://www.amazon.it/dp/B07KH33WRV/?tag=tomsforum-21) and on front putting 2 of these fans(https://www.amazon.it/dp/B00ECWKD6I/?tag=tomsforum-21), what do you think is it a good choice or there is better option for this budget 40 euros
i need a good rear fan with rgb price range 20 euros, and 2 frontal fans without rgb price 20 euros max 30, link me some fans
just link the best for my budget, those who already suggested me are not available or are over prices please i need help
https://linustechtips.com/topic/1108574-case-fans-cheap/#findComment-12927905
If possible, I'd recommend getting fans with better static pressure for the front since the front panel is fairly obstructed.
Why not keep using the stock case fans?
If you're trying to determine how much cooling you have, list your specs.
If you've already been using the case with the stock fans, list your current load temps as well.
This is a forum and not live chat so it's pretty normal for replies to take a day or so.
Please don't spam the thread with posts -- thread cleaned.
https://linustechtips.com/topic/1108574-case-fans-cheap/#findComment-12929597
hi, thank you for your reply, im changing the fans cause 1 is broken and the temperature goes to the 70 75 and sometimes 78.
And can u suggest me which one to buy for the front x2 and which for the rear x1 the rear one possibly rgb max budget 50 euros
https://linustechtips.com/topic/1108574-case-fans-cheap/#findComment-12929706
What are your specs? Are these load temps?
Is the case under warranty? If so, you can probably get a fan replacement from the manufacturer.
https://linustechtips.com/topic/1108574-case-fans-cheap/#findComment-12929714
specs; ryzen 7 3700x, rx 5700xt gigabyte 3 fans model, x570 asus tuf, 16 gb ram 3200mhz corsair, hdd toshiba 1tb, ssd samsung 860 evo 500gb,psu cx550m, while im gaming the temps goes from 70 to 78, and nope my case is not in warranty anymore
https://linustechtips.com/topic/1108574-case-fans-cheap/#findComment-12929718
Your temps seem pretty normal. More airflow wouldn't hurt but it's not necessary.
If you're mainly aiming to fill the case with rgb for aesthetics, you can use an RF120 3-pack for top / rear exhaust: https://www.amazon.it/DeepCool-RF120-Silenzioso-Prestazioni-Controllabile/dp/B0799DML5Y/ref=sr_1_1?__mk_it_IT=ÅMÅŽÕÑ&keywords=cf120&qid=1569832357&s=pc&sr=1-1
The other 2 working stock case fans can be used for front intake.
https://linustechtips.com/topic/1108574-case-fans-cheap/#findComment-12929757
https://linustechtips.com/topic/1108574-case-fans-cheap/#findComment-12929768
https://linustechtips.com/topic/1108574-case-fans-cheap/#findComment-12929791
ok thank you very much for your time and for your help
PS my case doesnt support 140mm on front xD so im gonna grab the 120mm one
https://linustechtips.com/topic/1108574-case-fans-cheap/#findComment-12929796
It supports 140mm's at the front.
https://linustechtips.com/topic/1108574-case-fans-cheap/#findComment-12929814
29 minutes ago, MrBigD1409 said:
https://it.sharkoon.com/product/3713/19304#specs lol then this is wrong xD cause here it says on top xD
It's probably incomplete. You can pull off the front panel and check for yourself.
https://linustechtips.com/topic/1108574-case-fans-cheap/#findComment-12929861
