I have a Cooler Master MC500M
I am looking at the Cooler Master vertical bracket - MCA-U000R-KFVK00 (LINK)
am i right in thinking I wont be able to use any of the other PCIE slots? i currently have a Wifi card
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
https://linustechtips.com/topic/1107629-vertical-gpu-mount/
As you can see, the riser uses up 7 slots (red). Unless you do some modding, all slots will be used up.
Realistically, you could cut off the top part (blue) and use the top slot for a wifi card (not that I would recommend that..). Of course check if the slot you will use for the GPU has plenty speed though.
Oooor.. You could just not bother with vertical mounting and have a normal PC, with better airflow and expansion slots you can use (plus, you have to check if you cooler won't interfere with your vertically mounted GPU)
https://linustechtips.com/topic/1107629-vertical-gpu-mount/#findComment-12917866
Realistically, you could cut off the top part (blue) and use the top slot for a wifi card. Of course check if the slot you will use for the GPU has plenty speed though.
But.....but...but.... it looks soo nice.. my shiny Nvidia 2070 Super FE would have looked lovely ?
But you are probably right.... just stick to having a "normal" PC lo
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1107629-vertical-gpu-mount/#findComment-12917905
It might work,what Wi-fi card do you have?
He has a PCI-E x1 Slot as the first slot on his motherboard,if his Wi-fi cars is x1 PCI-E then he should be good to go after cutting the top part you marked.
I have a crazy high-end Wi-fi card and it only uses PCI-E x1,I have the ASUS PCE-AC88 AC3100,It does 750MB~1GB depending on signal interference.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1107629-vertical-gpu-mount/#findComment-12917962
I have the Archer t9e ac1900 wifi car.
didnt really wanted to start cutting the frame.....
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1107629-vertical-gpu-mount/#findComment-12917974
That's the only way,nice car by the way :D
https://linustechtips.com/topic/1107629-vertical-gpu-mount/#findComment-12917982
lol its the future....
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1107629-vertical-gpu-mount/#findComment-12917985
