You could use regedit to fool the more basic programs, but those meant to read correctly like CPU-Z can't be tricked without modifying the BIOS.
Desktop benching:
I think some virtual machines can do it.
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
I am looking to start my build with Linux wold you have a recomdation for what one I should go with if wanting to modifying the BOIS
why would you want to fake the hardware in the first place?
Desktop benching:
something like fake gpu by flashing bios to a different card?
what next?
I am looking to run an os but it does a hardware scan and will not let me run it. But I am looking to do it on a virtual desktop for testing
which OS, out of so many Linux variants?
Desktop benching:
I am looking to run the original Xbox os but I'm being hardware blocked.
What Linux os would be best to run almost like a virtual machine.that I can preform a hardware fake.
7 minutes ago, 3Dimentinal said:
original Xbox os
then forget it. I've seen faking CPUs to different models that's in the same socket and architecture with the BIOS, not a completely different CPU architecture.
How expensive is an Xbox anyways
Desktop benching:
There's more to it than just showing up as different hardware, the original xbox didn't have an x86 cpu so you straight up can't run it on a normal pc without a full emulator. The vast majorty of good games for the original xbox are available for pc anyway so what's the point?
sudo chmod -R 000 /*
All right well thanks for letting me know but with me being me and all ima still try it may be a lost cause but I might have fun screwing around.
The Xbox used a Pentium III, so it was X86. The issue with this is that you won't be able to do anything with the OS even if you did get it to boot. There are just so many things that will prevent you from doing this at all.
Shoot even if I got it to boot I wouldn't be able to use it?
Yeah, that's not really going to work. You're much better off just getting an old Xbox. You can get one for around $10-15 USD used in working condition.
Ahh man I was hoping to have a project to work on
yes, software pretending to be a hardware is called emulator. If you are interested in creating one, this is the highest view of what it may look like.
char* memory = malloc(40000000000); // reserve a memory of 4GB for our virtual machine
void run(instruction next_instruction){
 while(1){
  switch(next_instruction){
    case add: rd = rs + rt; // add registers
      break;
    case subtract: rd = rs + complement[rt] // subtract
      break;
    case jump: ........ // jumping to another instruction and so on.
Of course in reality it is much more complicated but that is the general idea pretty much.
http://marc.rawer.de/Gameboy/Docs/GBCPUman.pdf
Guide on gameboy cpu and its instruction set. Go have fun.
Sudo make me a sandwich
about the closet i think you can get to what you want is to try looking up these
xbox specs
and using source / template design form one of these
Qemu and Qemu wikki
bochs and bochs wikki
to build  a new bios/ computer hardware set  (as wasab said) with appropiate mapping.
ie hdmi to your graphics card / screen, xbox controller to keyboard/ mouse etc.
however if there is any DRM or security features that are looking for specific Identification of the xbox it will still probably fail.
current main system: as of 1st Jan 2023
motherboard : Gigabyte B450M DS3H V2
CPU: Ryzen 5 3600
ram : 16Gig Corsair Vengeance 3600mhz
OS :multi-boot
Video Card : RX 550 4 GIG
Monitor: BENQ 21 inch
 while(1){
      break;
      break;
Awsome thank you I definitely will
xbox specs
Qemu and Qemu wikki
Okay thank you so much
