best joypad for Note 10+ need help
can someone recommend a joypad for me? It would be nice if it was compatible with both note 10+ and note 9. I use it to play emulators. Will be using it to play street fighter 2 and other emulated stuff.
CPU: 8600k @4.9  (1.39v) |  Cooler: NH-U14s | Mobo: Asus Strix z390i | Ram: Gskill DDR4 Trident Z 3600 8GB x 2 16-16-16-36
GPU: Gigabyte G1 1080 GTX | Case: Prodigy ITX | Fans: NH-A14, (exhaust) NH-A12, (intake) NH-A20 (intake)
Samsung EVO 1tb | Samsung EVO 512gb x2 | Intel ssd 128gb
PSU: Powerstation 500W
https://linustechtips.com/topic/1106516-best-joypad-for-note-10-need-help/
xbox one controller should be able to work through blue tooth and so can the switch pro controller  but I hear it has issues with latency could be fixed no but these 2 are the my favorite controller currently
thanks for the reply but I was wondering if you could recommend a more android specific controller
I recommend the 8Bitdo Sn30 Pro+ : https://www.amazon.com/8Bitdo-Sn30-Pro-Bluetooth-Gamepad-Sn/dp/B07T8JKVNT/ref=sr_1_3?keywords=sn30%2Bpro&qid=1569304887&s=gateway&sr=8-3&th=1
It has detachable hand grips, can be used with android, switch or pc, and is pretty comfortable IMO
