What do you think of this build? Are there any problems with it?
I came up with this build a few days ago and want to buy it today. Could anyone just have a quick look on the parts and tell me if anythings is wrong about them and if everything is compatible etc? Thank you :D
PCPartPicker Part List: https://pcpartpicker.com/list/dp8btp
CPU: AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor  ($238.90 @ OutletPC)
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard  ($199.00 @ B&H)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory  ($99.99 @ Amazon)
Storage: Samsung 860 Evo 500 GB 2.5" Solid State Drive  ($74.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 2060 SUPER 8 GB AORUS Video Card  ($449.99 @ Newegg)
Case: Cooler Master MasterBox MB530P ATX Mid Tower Case  ($129.99 @ B&H)
Power Supply: be quiet! Pure Power 11 CM 600 W 80+ Gold Certified Semi-modular ATX Power Supply  ($90.99 @ SuperBiiz)
Total: $1283.85
Generated by PCPartPicker 2019-09-19 10:03 EDT-0400
Drop from 600 watts to 550, 3600X to 3600, cheaper SSD, you get room for a 2070 super instead of 2060 super and it's still cheaper.
Primary PC:
Total: $1283.85
the 5700 xt is faster than the 2060 super, but I can understand if you want ray tracing
thanks :D I'll think about that.. the reason why i used the 3600x is cause i have to use the pc for school to (coding and stuff like that) do you think the 3600 will be enough for that?
yes, i know.. i thought about taking an amd card for a while but i like the rtx series :D thanks
The 3600X is practically just the 3600 with an X in the name, almost no difference. You say you use it for school, what schoolwork tasks will you be doing? Super complex 3D models and huge code compiling? Or just typing an occasional script and word processing?
Primary PC:
Well, I am attending a school which primarily focusses on coding and computer science. We arent doing huge code compilations or anything like that. At least now XD. We only have to compile some bigger projects ocasionally. I would like to do some 3D renderings for game dev and stuff like that but nothing too complex either in most cases
The 3600 does all you need and then some.
Primary PC:
17 minutes ago, Vntto said:
just one question: What is the differnence between the 3600x and 3600 then, as the 3600 costs a lot less?
Just a small clock speed increase on the 3600X
Primary PC:
