Omg I need help I feel like smashing my pc
My specs for my pc I i5 4440 16gbs ram gtx 1050ti asrock h81m-hds my problem is the audio will not work at all it was working not 2 long ago I have tried everything wiping the computer installing all the realteck drivers ect but the front pannel audio and the motherboard audio will not work I need help it's just going to be a siting brick and a broken one soon from the frustration!
https://linustechtips.com/topic/1105470-omg-i-need-help-i-feel-like-smashing-my-pc/
Boot into Live Linux and if there is no audio there i guess your audio chip is fucked. USB DAC is pretty cheap.
This is the manual for the motherboard - check page 22 - http://asrock.pc.cdn.bitgravity.com/Manual/H81M-HDS.pdf
Check front audio cable from the case is connected to the front audio header. on motherboard
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
