Upgrading my GTX 1070 for RTX card worth it ?
I was thinking about graphics card upgrade for new upcoming games, as I have i7 6700k 4GHz , 16GB DDR4 2400MHz, MSI GTX 1070 ARMOR OC , 1920x1080 144Hz ( 2016 build ). As of now I can play every game on ultra settings but because of new upcoming titles which are super crazy, I am worried about my system. Should I upgrade my card ? or should I wait for RTX 3000 series ?
https://linustechtips.com/topic/1105298-upgrading-my-gtx-1070-for-rtx-card-worth-it/
No, you're fine for now, and probably for a long time. Upgrade only if you need.
CPU: AMD Ryzen 5 2600X  |  Cooler: Cryorig H7  |  Motherboard: MSI B450 Mortar  |  Case: Fractal Design Meshify C Mini  |  RAM: 32GB DDR4 3000MHz  |  GPU: EVGA 1070ti Gaming (Kraken G12 Watercooled) |  PSU: Corsair TXM650  |  Storage: Samsung 860 EVO 500GB + WD Blue M.2 500GB  |  Network Card: Asus PCE-AC56  |  Monitor: Acer Nitro VG270U  |  Audio: Sennheiser HD6XX + Schiit Fulla 2
Laptop:
Lenovo s540:  CPU: AMD Ryzen 5 3500U  |  RAM: 8GB DDR4 2666MHz  |  GPU: AMD Radeon Vega 8  |  Storage: 256GB NVME SSD
If I'm playing games on high setting with an I5-7400 and a GTX 970 then you should be fine for a long while, I think maybe years from now. Lol there are people still getting by on 7 year old hardware but, on lower graphical setting of course.
You will know in time when the performance does not meet your criteria, hopefully by then something way better will be out.?
Gaming With a 4:3 CRT
System specs below
CPU: AMD Ryzen 7 5700X with a Noctua NH-U9S cooler
Motherboard: Gigabyte B450 Aorus M (Because it was cheap)
RAM: 32GB (4 x 8GB) Corsair Vengance LPX 3200Mhz CL16
GPU: EVGA GTX 980 Ti SC Blower Card
HDD: 7200RPM TOSHIBA DT01ACA100 1TB, External HDD: 5400RPM 2TB WD My Passport
SSD: 1tb Samsung 970 evo m.2 nvme
PSU: Corsair CX650M
Displays: ViewSonic VA2012WB LCD 1680x1050p @ 75Hz
Gateway VX920 CRT: 1920x1440@65Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@125Hz
Gateway VX900 CRT: 1920x1440@64Hz, 1600x1200@75Hz, 1200x900@100Hz, 960x720@120Hz (Can be pushed to 175Hz)
Keyboard: Thermaltake eSPORTS MEKA PRO with Cherry MX Red switches
What crazy games did you see with rtx? There is only watch dogs legion and cyberpunk 2077 next year. Am I missing something?
As for the gpu upgrade, wait for next years 7nm, the gtx 1070 is still very strong for 1080p.
Yea I know 1070 is very strong but after playing every games on ultra settings for 3 years I am having hard time even going on very high preset. Metro Exodus is the 1st game I had to play on high preset and below 70 fps kills me from inside for some reason. But I'll wait.
