odd gif problem
Solved by colonel_mortis,
I've had a dig into it, and it turns out this is a DDG-specific problem. When you drag the image from DDG, you are actually dragging the parent element, which has two children - the gif, and a hidden placeholder image of the first frame. I presume the placeholder exists so that it can be displayed while the gif is loading in DDG.
When you submit your post, the HTML is sanitised, which includes making invisible elements visible. This means that the invisible placeholder image becomes visible, so you end up with duplicates.
The best solution is to right click on "View file" in DDG and copy the link location, then paste that into the forum and let it embed.
