Corsair Vengeance RGB PRO ram and aura sync
Yeah, the Trident Z Neo line is specifically for Ryzen 3000 though. That really just means most motherboard vendors have it ojn their QVL and thus xmp profiles exist for it on x570 boards and they guarantee stability with it. More attractive is the pricing and the large variety of 3600 mhz kits with decent to good timings. My recommendation would be 3600 over 3200, mostly because they do generally work out of the box with minimal setup and running IF and your ram in 1 to 1 does help squeeze out some performance. LTT has a pretty decent video on the impact of ram speed and timings on the new ryzen platform and G-skills rgb implementation works better with other ecosystems. Corsairs vengeance pros are still really designed for using icue for their lighting control and ask a pretty big premium for their Rgb. At least overhere the 3200 mhz cl18 corsair vengeance pro (white) kit was still 35 euroes more expensive then G-skills 3600 mhz cl 16 neo kit.
