The system I'm building is:
- Ryzen 5 3600
- RX 5700 XT
- 16GB DDR4 (probably 3200MHz 15CL)
- 2 Storage Units [1TB 7200RPM (probably) and a 2TB 5800 which is my old storage]
- B450 Tomahawk (most likely)
My question is (you guessed it!) the ideal PSU for the system.
Now, I've read some things about PSUs, included the "How many Watts do I need" thread on this forum, but I still don't know exactly what to look for.
It seems as though there is virtually no difference in the specifications between PSUs (about 90% of them have similar wattage and are rated 80 Plus Bronze), most models make no mention of the 12V rail, brand-names sometimes cost less than no-names, and sometimes higher wattage PSUs of the same brand and with the same features cost less than their lower wattage counterparts...
So...
What should I get to power this system reliably?
The calculator from Outervision recommends the EVGA 650W BQ 80 Plus Bronze. Even though the recommended wattage is 457 watts, Outervision recommends a PSU of 650W. I understand that I need headroom, but would 600W not suffice? Also I am not 100% sure that I will be able to get my hands on the PSU mentioned above.
From what I've seen on offer from local vendors, PSUs that come at a comparable price and meet the specs from Outervision are:
- Cooler Master MWE 650W, 230V, 80Plus Bronze
- Corsair Builder Series CX, 750 Watt, ATX, EPS12V
- Deepcool DA600-M 600W 80Plus Bronze Black
- Deepcool DA700N 700W 80Plus Bronze Black (this one costs less than the 600W one)
- Cooler Master MasterWatt Lite 600W, 230V, 80Plus
Are these good?
I am open to suggestions.
I am not looking to overclock or make significant upgrades in the near future. I just want a stable and reliable PSU for what will be my most powerful system to date.
Peace
https://linustechtips.com/topic/1104915-help-me-choose-a-psu/
