In need of a psu - help :D
CriSis_
Hi all,
I have once again changed my build and am now in need of yet another psu recommendation. The psu needs to be within the budget of £50 or under and must be able to power a 1660ti + 3600 both overclocked, 16gb of ram (possibly ocd) and a b450 tomahawk max. Many tahnks in advance for any recommendations :D
Thanks,
Lex.
20 minutes ago, Alexander Underwood said:
Hi all,
Thanks,
Lex.
Get a CX550 if you ask me. Leave some overhead for future upgrades and quieter operation hence the 500Aw recommendation
Seasonic M12II-520Semi-Module 520W ATX12V Power Supply Unit - Silver
https://www.amazon.co.uk/Seasonic-M12II-520Semi-Module-ATX12V-Power-Supply/dp/B0038T0V8Q/
be quiet! System Power 9 500 W : https://uk.pcpartpicker.com/product/b37v6h/be-quiet-system-power-9-500-w-80-bronze-certified-atx-power-supply-bn246
SeaSonic S12II 520 W 80+ Bronze : https://uk.pcpartpicker.com/product/fZyFf7/seasonic-power-supply-s12ii520bronze
Corsair CP-9020120-UK CX Series 450 W CX450 ATX/EPS 80 PLUS Bronze Power Supply Unit - Black  https://www.amazon.co.uk/Corsair-CP-9020120-UK-CX450-Bronze-Supply/dp/B06WW51XBX/
Corsair VS650 650 W Active PFC 80 PLUS Certified Power Supply Unit - Black  https://www.amazon.co.uk/Corsair-VS650-Active-Certified-Supply/dp/B078Y32P1W/
Silverstone ET550-B 550 Watt 80+ Bronze PSU/Power Supply
550W Silverstone Essential Series ET550-B, Fully Wired, 80PLUS Bronze, Single Rail, 42A, 120mm Fan, ATX PSU
https://www.scan.co.uk/products/550w-silverstone-essential-series-et550-b-fully-wired-80plus-bronze-single-rail-42a-120mm-fan-atx-ps?
I had been looking at both the cx450 and the bequite psu. Would the dual rails on the bequite psu cause issues with system balance i.e - ssds, hdds get more power than needed and the rest of the system is limited?
Thanks for the help,
Lex.
:D
39 minutes ago, NunoLava1998 said:
bet u didnt know the CX450 is 45 pounds in the UK :D
I do not believe noise will be much of an issue, given that 1660ti+3600 consume like 200-250W max during gaming
Garbage
Not garbage, but it's still on the lower end of PSU. Why get that when you cuold get a CX450 for cheaper, with a more modern half bridge LLC primary topology?
Group reg, skip. Still better than the s12ii/m12ii garbage tho..
Another trash group reg, skip again
Just now, hello_there_123 said:
I suggested the pure power 11 400w as it is Corsair RMx level power supply; which is better than the CXM.
The CX/CXM is also good though
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
Lex.
:D
No; that's only with really shitty/old power supplies.
The Pure Power 11 is a modern high-quality power supply; you'll 200% be fine
LOL
 trolling or for real? There is no way anyone could realistically think that the pure power is anywhere close to rmx in quality...
ACRF primary topology puts it behind the Corsair CX non M in quality
Garbage
I managed to find the cx450 for £42 in currys in store xD, Think it might be a good idea though to get a cx550w in order to have some gap left for an oc on my cpu, gpu and ram (will have to oc my ram).
Thanks for the help :D,
Lex
gpus like 120-150W, cpu 70W, RAM 10W. That's with max OC on all parts btw
3 minutes ago, hello_there_123 said:
LOL
It legitimately is, actually.
The low end PSU line of beQuiet! is the System Power line
edit: saw your edit; it still is a pretty decent PSU
Sauce...?
1 minute ago, seon123 said:
Sauce...?
Looking at reviews looks like it's a good power supply except for the voltage regulation and ripple which are at pretty high levels; but nothing that would actually damage components
1 minute ago, Alexander Underwood said:
Thoughts on the psu war xD - Your recommendation :D
either is good honestly
Build quality and the numbers on an oscope/multimeter are two different things. Jonnyguru, Mask, Rexper, Orion, Stefan Payne and a few others are the most competenent enough to judge build quality.
Garbage
edit :  black = hello_there_123's comments
- may be older design but it has 5 years warranty, it's semi modular, it's bronze rated and gets close to 87% efficiency and it's 48 uk pounds.  It's not garbage.  May be group regulated but who the fuck cares on a system that consumes 200w
Maybe because it's proper 500w, while CX 450 that's cheaper it's probably the 2015 model (not the newest CX series) so it's not really that good of a deal
Stop with your group regulation complaint, you probably don't even know what that means, just repeating others.
It's absolutely irrelevant to this person's computer, which barely uses 200-250w, if the psu is group regulated or not.
It's not better than m12ii  or s12ii , it's a shitty psu with shitty components and capacitors, which is rated for 30c ambient temperature and must be derated if used at higher than that - every other psu is rated for 40c or 50c .. it also has only 2-3 years warranty.
I only listed it because it's cheap price and because even with derating it, it can still do 450-500w safely, and if the guy goes for the higher wattage psus out there, might as well go for something SAFE-ish.
The S12ii is old design, but at least it's made with quality components (fan, capacitors, parts etc), and has long warranty... yeah it's group regulated but for that system IT DOESN'T MATTER
13 hours ago, mariushm said:
Garbage
isnt it the m variant of the cx series that is the 2015 edition? https://www.corsair.com/uk/en/Categories/Products/Power-Supply-Units/c/Cor_Products_PowerSupply_Units
the cxm has a 2015 and a 2017 version
but the 2017 shows barely any differences
the difference between these cxm's and the cx non-modular shows some good changes though
Might I ask what you would recommend for a £55 or under budget ?
Best,
Lex
is no uvp a good reason to completely burn it to the ground? not meeting c6 sleep states?
there's no 2015 cx, that's the cxm, which is about on level with the sp9
i recommend you do some research on what group regulation actually means for crossloading and how the 5v can go out of spec when you don't load it and do load the 12v. and then complain about people not knowing their stuff
you may
this pure power 11 would be a pretty good choice in my opinion
https://uk.pcpartpicker.com/product/t8c48d/be-quiet-pure-power-11-400-w-80-gold-certified-atx-power-supply-bn292
system power 9 is pretty decent as well, but this one only costs 3 pounds more according to pcpartpicker
1 minute ago, LukeSavenije said:
you may
Do you think 400w is enough for a 3600, 1660ti and ram all overclocked? Should I look into the pure power 11 500w :D
Lex
Honestly, I retract my CX450 recommendation. Since it doesn't come with a 6pin and the pure power 11 400W does
I was looking at that last night xD, only realised that myself yesterday haha
