Long Long process short story: I have been having some problems with my 9900k, with Overclocking (first timer) and temps (240mm AIO).
I want to make a first time custom loop sometime in the next few months, potentially.
But I need help with my current cooling solution, the overclock, and the potential of returning the parts tomorrow; as it is the last day I can go in and RMA both the CPU and MOBO for direct replacements or store credit.
1st.) Prime 95 has killed any OC I have thrown at it, aside from like 1.1v @4.6ghz with temps at like 99 throttling.
2nd.) Ive gotten 4.9ghz & 5.0 ghz stable, but at 1.2v @4.8ghz Ive gotten the only temp range that I am wanting to stick to. Here are those results from my reddit post:
1.2v @ 4.8ghz - AVX offset @3 - LLC @5 - 45 Cache - XMP 1 - VCCIO @1v - System Agent @1.1v. Im running stable on real bench 83/84 degree temps - Aida64 full load with AVX on im sitting at about 80/81(ie: 4.5ghz because of offset) and without AVX on im sitting at 79/80 (Full 4.8ghz). FPU only hitting a max of 93 but settled to 91. Cinebench capping out at 83-84.
3rd.) A lot of the feedback I have received so far is that the issue is potentially the cooler? But I think its the chip maybe, i dont know. The cooler seems to be working fine. I just recently upgraded from a 6700k, which yes I know the 9900k is a completely different beast with thermal monstrosity, but the cooler I know is working fine. Yet, I've started to doubt that with all the outside thoughts on it.
4th.) The reason I think it is the chip is that now, turning my OC off with just XMP on I am getting ridiculous temps. Cinebench is spooling up to 91-93. CPUZ is telling me voltage is at 1.234v (after the .05 v droop I think I have), this is with the cpu staying at 4.7 ghz. 15 seconds into Aida is sending me to the upper 90 degrees & 1.288-1.305v (auto LLC is going to 2). And then it drops down to 4.1ghz to keep temps at the 70 degree @ 1.1v after droop. (This is with everything set to Auto, but Asus multicore Disabled. Enabled yielded a few more degrees)(XMP set to auto keeps cinebench temps down to 88) Do I just have something really wrong in the bios with the OC turned off that I'm not realizing?
I have gotten the best results temp wise from my 4.8ghz OC. 4.7 Was a little lower as well, but 4.8 yielded temps that were acceptable. I am getting the lowest boot temps, stress test temps, everything with the 4.8 OC.
What do I do? I am willing to work with the OC all night, but I do need to decide what to do. The chip itself seems decent on an OC standpoint. I got 5ghz running at I think 1.28v. Temps were just 10 degrees or so higher than 4.8ghz.
Also it looks like my idea Vdroop is about .046 ( 1.2v in bios, 1.154 under load) (LLC @ 5).
Ask away I'll be very responsive so I can hopefully get some insight on what to do!
9900k
Asus Rog Strix Gaming -E z390
32gb Ballistix 3200mhz ram (dual channel)
Corsair h100i v2 240mm AIO
https://linustechtips.com/topic/1104158-9900k-help-rma/
40 minutes ago, OhNoItsApollo said:
a couple of things that sticks out, the mobo vrm is kinda meh, so any 135w+ load (especially in prime, just don't use it) without airflow  is gonna put the vrm over 100C creating possibile stability issues, this is actually what i'm worried about the most.
the h100i is barely enough for the 9900k. I'd guess 1.25v 4,9 (non-avx) is a sweet spot.
Prime is overkill on heat, do OCCT for stability, spam cinbenech R20 (5-10 runs in a row)  for real world workload temps
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1104158-9900k-help-rma/#findComment-12890351
the h100i is barely enough for the 9900k. I'd guess 1.25 4,9 (non-avx) is a sweet spot.
Should have gotten a Gigabyte mobo as those VRMs on that ASUS board is not that good.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1104158-9900k-help-rma/#findComment-12890365
I hope you were using Prime95 v26.6.
later versions will cook your CPU.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1104158-9900k-help-rma/#findComment-12890378
So far from all my testing my vrms haven’t gone anything over 50C. I got 4.9 stable at 1.25 and 5 at 1.28. They both got the same temps, with the 1.28v maybe 2-3 degrees higher. Both were in the low 90’s though.  Will do that as soon as I’m home. But do you think rma ing is worth it then?
https://linustechtips.com/topic/1104158-9900k-help-rma/#findComment-12890436
def not worth RMAing, it's a difference of 100mhz. I doubt you'll get anywhere near the prime temps doing anything else, my gaming temps are like 75C in destiny/division 2, 85C on cinebench, it'd probably hit 100C too on a hot day with prime small fft, completely unrealistic load.
https://linustechtips.com/topic/1104158-9900k-help-rma/#findComment-12890457
