(Slightly) higher temps after thermal paste re-application?
Computernaut
I recently acquired a new computer and as part of my usual new-computer routine I replaced the thermal paste. Before replacing it, temperatures after a 20 minute stress-test were 83-86 degrees, but after the re-pasting with the same test, I was getting readings as high as 90. It's not a big difference, but I'm not comfortable with such high temperatures on my CPU (that's part of the reason I re-applied the paste). I went into the BIOS of the computer to see if there was any option to adjust the fan-curve, the computer is very quiet even under load, so I though it would be fine to ramp the fans up a little more. Unfortunately, like many older business computers, this one has a very basic BIOS and the only thermal-related option I found said something about the fan at idle.
The CPU is an i5-4570.
What is actually supposed to go here? Some people put their specs, others put random comments or remarks about themselves or others, and there are a few who put cryptic statements.
What cooler (and what paste did you use as well)? Mounting pressure may have been different.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
Fans are designed to run at 100% rpm so raising the fan speed shouldn't be an issue.
As mentioned, the cooler might not be properly mounted. What cpu and cooler are you using?
Have you tried reseating the cooler?
It's generic pre-built business computer, so I don't know the exact cooler, but it was a fairly basic upright fin, dual heat-pipe cooler with what looked like a ~60mm CoolerMaster fan on the front. I don't think I changed anything about the cooler or how it went on so I don't how the mounting pressure could have been different. The model of the computer is HP EliteDesk 800 G1.
Hey WoodenMarker do you think the cooler is utter junk possibly assuming what you said and he reseated it firmly.  I wouldn't be running stress tests on that computer my friend.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Does the cooler use screws like this?
If so, make sure that the cooler is gradually and evenly tightened down in an X-pattern instead of one side before the other. Also, tighten it fully. An uneven mount can easily result in bad cooling.
If it's like the cooler I linked above, it's certainly not junk.
Stress tests are fine. The cpu would shut down if it gets too hot.
  Hide contents
Here's an image I found of the exact computer I have (minus the 1050):
Keep in mind, the computer came with this cooler and CPU.
That's even better. The 4570 is easy to cool and the cooler is most certainly mounted incorrectly the temps are correct. Try reseating it and making sure it's fully and evenly tightened.
The fan is plugged in and spinning, right?
After re-seating the cooler (and replacing the thermal compound, just for good measure) and making sure the fan was all good, I tested it and got temps of around 80-84; not as good as I'd like, but better than it was before.
Thanks for your help, guys.
