Basically someone phoned me and the exact moment it started vibrating this happend, the first pic is youtube the second is discord
CPU: Amd Ryzen 3400g
COOLER: Be Quite Dark Rock Pro 4
MOBO: Aorus x570 elite
RAM: 2x8 Corsair Vengence 3200 MHz
SSD: Samsung 970 Evo Plus 500GB
GPU: Powercolour Red Devil RX570 4GB
PSU: Corsair RM750x 80+ Gold
CASE: Coolermaster H500p Mesh
https://linustechtips.com/topic/1103330-help/
Just now, 5x5 said:
That's one doomed.graphics.card
I dont have a graphics card... and the system is a week old...
https://linustechtips.com/topic/1103330-help/#findComment-12883471
Please list your full system specifications. Also, do you have a second known good working monitor you can try? Or can you try this monitor with another working PC?
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/1103330-help/#findComment-12883497
Yeah you do, be it integrated or a card. Your computer has to display somehow.
Either way, a few things todo:
- unplug your monitor and computer (power and HDMI/DP/VGA) and connect everything again.
- if the problem is still there try another cable (HDMI/DP/VGA)
- if you have a laptop or another computer try those with the screen.
- try another screen. You can prob hook up your TV to test.
https://linustechtips.com/topic/1103330-help/#findComment-12883498
Update turned the pc of for 7 hours and came back and it works, thats how im now talking to you
https://linustechtips.com/topic/1103330-help/#findComment-12884193
