Hello!
I am ex pc user that moved to Mac and regretted it profoundly, I ordered a custom pc for gaming ( mostly racing sims) and am looking for the best bang for buck display out there, I checked out ROG's 65" 2.5K$ monster but apparently there are too many flaws for the price. I had a look around but it seems most monitors are in a transition phase and I dont know when the improved ones will come, so question is, should I wait, if so how long do you think? or what should I get now?
Thank you very much!! all help appreciated. oh and my pc build can run 4 8k monitors so that shouldn't be the issue
If you're looking at 65" monitors, do you need one that large?  Ultrawides?  Multiples?  Or even the super ultrawides?
What setup do you WANT?  Then we can help find the right monitor(s) for it.
4 8K monitors?  Okay.
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
OnePlus Ecosystem:
Other Tech:
1 hour ago, Newpcgamer1 said:
Hello!
I've been waiting about 4-5 years.. trust me dont bother. The industry is perfectly content milking the ever living crap out of LCD.
You wont find a 'perfect' monitor. You will always end up sacrificing something, almost always picture quality related, especially when looking for a gaming orientated display.
Best bet, check out rtings.com and tftcentral reviews.
rtings has a little tool for searching through reviews by test results. Link below is for monitors, they also have one for TVs.
https://www.rtings.com/monitor/tools/table/6969
add and subtract columns as needed.
if ur looking for a LARGE display consider either the Samsung Q900 , its a 8k QLED, great quality and good figures for gaming. Also the Q90 which is the 4k variant.
At the same price range for the size u can get an OLED, so consider those as well if ur ok working around the so called 'burn-in', they are far superior to LCD, even the QLED LCDs.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
thanks for the quick reply, I would either like 1 display, maybe curved to be just behind between by steering wheel and my pedals, so, rarely close, either I will get 1 display that is good enough for my use or go triple monitor, I am open to ultra wide, I dont know how much load a racing game puts out on a monitor but can't imagine it being as bad as a fps or something. what would you recommend ? I asked for my custom pc to run games smoothly at full settings without noticing frame drops or anything that will take away from my immersion and fun
my bad for the typo, I can run 4 4k monitors, here are my pc specs
Logitech (MK270) Wireless Keyboard & Optical Mouse - (Wireless)
    2 TB Seagate (2000 GB) SATA-III HDD 7200 RPM 64MB Cache
    1 x 1.8 Metre UK Mains Power Cable
    Microsoft Windows 10 Home 64 BIT
    Asus Dual Band Wireless Network Card 600Mbps & 1300Mbps (PCI-E)
    Corsair Hydro H100i Platinum RGB Pump & 2 x 120mm RGB Fans (Advanced Liquid Cooling)
    Corsair RMx 750W Gold (Modular) PSU - Low Noise / Silent
    Asus PRIME X299-DELUXE (Intel X299) - 6xUSB3.1/4xUSB2/WiFI/RGB
    Corsair 32GB Vengeance LPX 3600MHz (4x8GB) - Lifetime Warranty (DDR4)
    Game Max Eclipse (3 x RGB Fans) - Tempered Glass
    FREE - EU FedEx Delivery
    3 Year Extreme Warranty (3 Year Collect & Return)
    Built & Tested - 9 Working Days
     1 TB Samsung 970 EVO M.2 SSD, Read 3400MB/s, Write 2500MB/s - Silent
    NVIDIA GeForce RTX 2080 Ti - 11 GB - (PCI-E) - DP/HDMI - HD/4K/VR - Supports 4 Monitors - TODAY ONLY LOW PRICE
    Intel i9 - 9900X Extreme (10 x 3.5 GHZ - Turbo 10 x 4.4 GHZ)
@Newpcgamer1
A system may be able to physical connect and drive 4x 4k monitors on a desktop, but u can forget about running a game across 4 4k displays, thats 15360 x 2160. Thats way to much for even a 2080ti to handle.
Highest u could run with usable FPS is 5120x2160, and the only monitor that does that , that i know of, is the LG 34WK95U.
I know there are not many racing games if any that support 4k so idk, im aiming at around 1440p
The majority of games support almost any resolution. All racing games will support 4k, its only when u go into different aspect ratios could support be lacking, but for racing games that shouldnt be an issue as they are more suited to wider aspect ratios anyway.
I am getting the sense that you may be assuming a lot or misinformed, based on a few things you're saying.
So if you wanted a good racing monitor, i would do as @IDprofile mentions.  3440x1440p 120Hz Ultrawide.   Your 2080Ti will push it well.
OnePlus Ecosystem:
Other Tech:
  • 2 weeks later...
