Hello all,
So i built a new pc, and when i powered on the PSU, mobo just blinks for a moment and thats it.
I moved mobo out of the case, tried to power it on without GPU, same thing.
This is the part list.
https://pcpartpicker.com/list/QJGLCb
Any advices?
Thanks,
Jovan
https://linustechtips.com/topic/1101674-new-build-issue-not-starting/
2 minutes ago, emosun said:
are all the front panel connectors unplugged?
try powering it on without the gpu or drives plugged in
can also try it without ram as well just to see if you can get sustained power out of it
I pulled out mobo on the box again, only connected is cpu, ram, and m2. Let me try without ram and m2
you need to quote us so we know you replied
9 minutes ago, iJoVaN said:
yes, am i retarded? but, mobo has no indicators or lights on
the power supply switch just cuts power to the power supply
you have to connect the power buttons on the case to the motherboard and press the power button to turn the machine on.
3 minutes ago, emosun said:
your power button and front panel connectors are down here
https://imgur.com/4IHYXzk
i think that may have been the issue, where to apply for my 'im retarded' badge. il double check and get back to see if that was the case fml, brb :')
