Best Hard Drive for 24/7 Use?
Solved by seagate_surfer,
On 10/3/2019 at 4:04 PM, kingknightrider said:It seems the Ultrastar line and gold for that matter are prone to clicking and hard drive failures and possible grinding more so than not...
You spoke of Iron wolf line if NAS but would this one be better option?
https://www.amazon.com/Seagate-Exos-Internal-Drive-Enterprise/dp/B07D9C618D/
And for that matter isn't this the same drive -though most likely in a renewed/refurbished state:
https://www.amazon.com/gp/product/B01FRC1GRQ/
I vote for the Exos too! Regarding the refurbished, I find very difficult that this drive is refurbished, most likely it is just an older version and that's why is cheaper.
