Need help with Airflow setup.
Hey all, would airflow like that gonna be smart? Or keep the back as exhaust?
Or better would be to put the radiator in front as intake, put 3 fans on top also as Intake and back one exhaust?
67490450_346482119575025_6098510864879452160_n.jpg.8873eadb1d1387c0afaedfb30ed7dde5.jpg
Ignore the cable management, the pic is old.
P.S. The PC normally sits on wooden floor, not on a carpet :D
P.P.S. My VRM is clearly overheating, even after ~3mins of PC being off the heatsinks are pretty hot.
https://linustechtips.com/topic/1100986-need-help-with-airflow-setup/
Do you have actual proof of them overheating? VRM's operate fine up to 100C, and if you would touch them you would burn your hand at that temp, but it would be fine for them.
The usual, most traditional and most logical setup for fans would be :
front: intake
Top and back: exhaust.
If you are worried at the vrm temp, then radiator at the top exhaust makes more sense as front intake.
I only see your reply if you @ me.
I've tried during stress test few mins ago, was able to hold fingers on the VRM heatsink for like 3-4secs before it was about to burn, i even still feel very mild burning pain on one of the fingers.
Edit: the top heatsink is pretty cold.
Just now, Exaco said:
I've tried during stress test, was able to hold fingers on the VRM heatsink for like 3-4secs before it was about to burn, i even still feel very mild burning pain on one of the fingers.
WHYYYYYY
Why can't you just open cpuid HWmonitor, Corsair LINK, or any other monitoring software and just look at the VRM temperatures from there?
No need to give yourself first degree burns over nothing.
2 minutes ago, Origami Cactus said:
WHYYYYYY
^^^ 100C is the temp of boiling water, may as well slap your hand in the pot next time you're making noodles. Tis the reason they made monitoring software, so you can get reasonably accurate temps without either needing to buy more equipment or actually touch the hardware while it's all heated up.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
3 minutes ago, Origami Cactus said:
WHYYYYYY
I don't think there's a sensor for that or it's simply broken, it always says 29C no matter what.
For which sensor? Usually there's 2 or 3 mobo temp sensors, they're not always labeled as VRM (never have been for me, just tmp0, tmp1, etc).
Mouse: EVGA X17
Which software? Sometimes some software can read it, and some wont.
Anyways because you are not in the hospital, the temp was probably max 60-70c, so completely fine.
Here i've thrown all the temp sensors i found in HWiNFO.
I've even tried using the Asrock Tuning utility from mobo website it also says 29C.
There's probably reason why many youtubers use these Thermal lasers to check VRM Temps.
-snip-
Tried HWMonitor?
Mouse: EVGA X17
4 minutes ago, Exaco said:
Not sure if there's even VRM in there.
The TMPIN sensors are likely the VRM and other mobo sensors, none are over 100C or even 70C so you should be bueno.
@Origami Cactus
Lol, doubt 100c metal could make any damage when touching it with tip of the fingers.
If you just touch it for a split second then yeah. But you don't get an accurate measurement, only info you get is "this is a hot surface".
Fingers are not very accurate thermometers.
Mouse: EVGA X17
Still pretty sure the readings are fkd up thats why i switched to hwinfo which is superior in terms of readings and functionality such as RTSS OSD support. Before BIOS update the HWMonitor showed ~97c on something.
The TMPIN5 could be most realistic temp for VRM, but still imo it's bit too cold compared to how it feels especially considering i didn't even touched the actual VRM which probs would be alot more hot. But according to google skin can get burned from 44c, so that could make sense.
Personally I'd put that AIO in the front and set it up as an intake.  Put it as low above the HDD cage as you can, that way the bottom fan blows air towards the GPU and the top one blows its air more over the top half of the motherboard.
Keep the rear fan, but use it as an exhaust.
That's just 3 fans, which should be enough to keep a single-GPU system at reasonable temps ... if your case has enough airflow.  What case do you use?
If you really need more airflow, add 2 fans in the top.  Either have them at low RPM as intake fans or have the front-most one as intake and the other one as an exhaust.  You'll need to try both options to find out what works best on your setup.
Well i plan to get an x3 Fans for front as intake soon. Or i could use the china ones, but it uses Molex so not sure if that's even good to use.
Deepcool E-Shield
Your PSU fan arrow is to wrong way. PSU fans are intakes, but when they intake from outside the case, it's excluded from whole case airflow.
Otherwise all good. If you keep rear as intake, remember that it too needs filter. Most cases only have filters at bottom and front.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Yeah, it was mistake with the PSU, also i didn't think about the dust, thanks!
I'd say mount it as high as possible so the bottom fan can be just a fan so the GPU gets fresh outside air instead of air that's been heated by the AIO.
