Use whichever you'd like and then just make sure you use more than you think you might need (I'm assuming you haven't checked a bunch of different paste applications in the paste to learn from).  Honestly, if you apply in several spots on the IHS with the forethought of how it will spread once the cooler is applied you'll probably do a good job.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
1 hour ago, OlympicAssEater said:
Hello
Is the rice method thermal paste apply  work on Ryzen CPU or do I need to use the X method or the vertical line method on Ryzen CPU? I will getting all my parts on next week Monday or Tuesday.
Just dump a bunch on it.
1 hour ago, XHT_001 said:
-snip- if you die hard, buy some kitchen tongs to put the CPU into the socket
Lol.  wut?
22 minutes ago, nick name said:
Lol.  wut?
tongs, buy a good pair of tongs, to put the CPU into the socket with, if the top of the CPU is covered with paste, getting it into the socket and pressing it down firmly, normally ends up with you getting paste everywhere and all down the sides of the CPU and onto the pins and over the PCB, so use tongs
LOL. WUT!?!
You install the CPU into the socket before applying thermal paste.  Oh, gawd I am dying right now.
@Tristerin  Bro.  Brooooooo.  You'd like this.
@Streetguru Come back!
34 minutes ago, nick name said:
LOL. WUT!?!
This...this...is a first.  Is this how people get thermal paste all over the cpu pins lol?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
This is golden right here
That's some Verge level PC build guide advice.
Just ordered off amazon, googled - CPU tongs
This was in the top 3 selection, so I figured its going to be pretty good
I have those.  Great for CPUs like Threadripper.
1 hour ago, quakeguy said:
I always use a grain of rice on the middle of the CPU.  It seems to get almost full coverage when the cooler is attached.
Really?  "It seems to almost get full coverage".
Just do the rice/pea method. I've done it for both Intel and Ryzen and temps are perfectly fine. Other methods aren't worth the hassle in my opinion. For what? 1-2 degrees? If even that.
Main System: Ryzen 7 5800x | Asus Strix B550A | 32GB DDR4 3200Mhz CL14 | GTX 1080 | Fedora 36
Server: Ryzen 7 2700x | Asus Strix B450-F | 32GB DDR4 2400Mhz | GTX 1060 6GB | Unraid 6.10.3
Laptop: Intel i5 4200u | 12GB DDR3 1333Mhz | GT 740m | Windows 10
Mobile: iPhone 13 Mini | 128GB // Poco X3 NFC | 128GB
the best way is to put dots of paste every mm , small quantity of paste
  • CPU - AMD 2600 OC @ 4.0GHZ w 1.3v Stable : Cinebench R20 MultiCore : 3050 Single Core: 413 : Blender Rendering 75C Full Load
  • CPU Paste - Arctic Silver Ceramique 2
  • Motherboard - MSI B450M GAMING PLUS
  • RAM - Corsair Vengeance LPX DDR4 2x8gb 3000mhz CL15
  • GPU - XFX RX 580 GTS XXX
  • Case - DELUX CASE MT375 - Stripped to the frame for a better cooling
  • Storage - Samsung EVO 850 250gb
  • PSU - Segotep GTR 550
  • Display(s) - BenQ GL2250H
  • Cooling - Deepcool GAMMAXX 200T
  • Keyboard - A4Tech KD-126
  • Mouse - A4Tech N-400-2
  • Sound - AMD HD / RealTek ALC887
  • Operating System - Windows 10 Home
I just did the classic pea sized dot and it's working excellent for me using the stock cooler.
CPU: Ryzen 5 5600x  | GPU: GTX 1070 FE | RAM: TridentZ 16GB 3200MHz | Motherboard: Gigabyte B450 Aorus M | PSU: EVGA 650 B3 | STORAGE: Boot drive: Crucial MX500 1TB, Secondary drive: WD Blue 1TB hdd | CASE: Phanteks P350x | OS: Windows 10 | Monitor: Main: ASUS VP249QGR 144Hz, Secondary: Dell E2014h 1600x900
