I just built a new liquid cooling loop.  At idle, temps are 32C.  When I put load on it, temps instantly spike up.
  • Prime95 Smallest FFTs (high heat): 82C
  • Prime95 Small FFTs (max heat): 87C
Temps jump up instantly, then when I stop the test they instantly drop back to idle ~32C.  I hadn't expected them to spike that high.  Any suggestions what to do?
Things I've tried thus far:
  • Reseat the CPU block.  4 times.  With different thermal pastes (both from Thermal Grizzly).  And different application methods.
  • Flipped the block upside-down.  It's mounted symmetrically, so I figured it's worth trying.
Other things of note:
  • 2080 TI is liquid cooled.  Idles at 27C.  During load it slowly rises to ~48C.
  • Chipset is liquid cooled.  Idles at 30C.
  • Case is currently open during testing, so no restriction on airflow (at radiator or anywhere else).
  • Fans & Pumps are running at maximum during all the above tests.
  • Liquid temp is sitting between 26-28C.  It really doesn't move much.
  • Flowmeter is moving well.  Pretty sure there's no kink or cutoff in flow.
  • Temps measured in Ryzen Master.
  • The water is definitely flowing in the right direction through the CPU block.
  • I'm using the most recent BIOS (v1.80).
Hardware:
  • ASRock Taichi x570
  • Ryzen 3900x
    • EKWB Velocity Waterblock
  • Asus 2080 TI OC
    • EKWB Strix Waterblock
  • 560mm EKWB CE Radiator in push/pull (8x fans, EK Vardar static pressure fans)
  • 2x D5 pumps.
  • 32 GB Corsair RAM
https://linustechtips.com/topic/1099753-help-high-temps-on-new-liquid-cooling-loop/
You could try rotating the water block or cold plate (upside down will orient it more or less the same you need a 90* rotate).  Other than that it looks more or less normal for the 3900X from all I've seen.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
The mounts for the CPU block have 180* symmetry, but not 90*.  So a 90* rotation is not possible.
Quote
Really?  I assumed that temps would get that high under load?  Maybe I was just naive, but I had expected load temps to be more like 50-60C.
Is the issue just that heat can't transfer from the block to the water fast enough?
Then can you rotate the cold plate 90* degreses?  It's a theory some folks have had, but I don't know how well it will actually work.
And yeah, heat dissipation is much harder on a 7nm chiplet design.
Just now, nick name said:
Then can you rotate the cold plate 90*C?  It's a theory some folks have had, but I don't know how well it will actually work.
No, rotating 90* is not possible.  Only a 180* rotation, which had no effect.
(I didn't expect 180* to matter, but was running out of ideas on what to try)
You can't pull the cold plate out of the block to rotate it?
It's a square block . . . you can't rotate it 90 degrees?  Or are you tubes hard line?
Soft tubes.
Wouldn't disassembling the coldplate from the block leak fluid?  I'm not excited to drain the whole loop.
Soft tubes.
Well the person that claimed a huge temp drop didn't seem to account for ambient, but it did appear to reduce temps a decent amount.
So I guess it's just how much you wanna try to maybe see lower temps.  Because if you can't just rotate the block 90 degrees than fussing with the cold plate is definitely gonna take some work and care.
Sorry, but it seems odd that you can't rotate your block 90 degrees.  The mount should allow for that.
Edit:
Disregard.  I meant to say the block looks like it should account for it, but looking again it doesn't.
What is your ambient temp?  OC with high voltage?
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
1 minute ago, spiceygas said:
24C ambient.
All settings and voltages in BIOS are stock.
Ive read and watched videos a couple weeks ago about how the voltages in certain boards have to be tinkered with.  Link to read example:
https://www.techpowerup.com/forums/threads/ryzen-9-3900x-voltage-and-temperature.257295/
At stock (read from the BIOS):
  • CPU VCore Voltage = 1.488
  • DRAM Voltage = 1.200
  • VDDP Voltage = 0.936
  • VPPM Voltage = 2.528
  • CPU VD 1.8V = 1.824
  • CPU VDDCR_SOC = 1.024
  • PREM_VDDCR_SOC = 1.045
Offset CPU Voltage -5mV
  • Instant crash when I fire up Prime95
Manual CPU Voltage 1.35v
  • Verified CPU voltage in BIOS displays as 1.36v.
  • No other voltages sizeably changed.  (Minor fluctuations within margin of error)
  • Prime95 Smallest FFTs (High Heat) = Instant Crash
Manual CPU Voltage 1.40v
  • Prime95 Smallest FFTs (High Heat) = 83*C
    • One degree worse than @ stock
    • Seems within margin of error
  • Prime95 Small FFTs (Highest Heat) = 94*C
    • 7*C worse than @ Stock.
    • Probably outside margin of error
    • Ryzen Master has 95*C as the limit, and I assume the CPU is throttling.
So I would conclude that lowering voltages substantially causes instability, and lowering a tiny bit does nothing, and possibly hurts thermals.
Just for shiggles, I tried disabling Precision Boost Overdrive in the BIOS.  Fired up Prime95 and... instant crash.
Oddly, if I disable it in Ryzen Master then it's fine (see below).  So maybe I suck at using the BIOS...?
Ryzen Master set to "Eco Mode."
  • After reboot, it passed the AMD Ryzen Master Stress Test.
  • Prime95 Smallest FFTs (High Heat) = 48*C
    • Wow!  Huge difference.  (At a cut to performance, of course)
  • Passmark CPU Score = 31145
    • 2.1% below average.  (Link)
Ryzen Master Set to "Default" Mode (i.e. Not Precision Boost Overdrive)
  • Prime95 Smallest FFTs (High Heat) = 72*C
    • 10*C improvement over stock
  • Passmark CPU Score = 31802
    • 0.08% below average.  (Link)
Ryzen Master Set to Precision Boost Overdrive
  • Passmark CPU Score = 32019
    • 0.60% above average.  (Link)
My Conclusions Thus Far
  1. Leave the voltage settings alone in ASRock Taichi x570.  Things become unstable really quickly.
    • Your mileage may vary on other motherboards.
  2. If temps are running high, set Ryzen Master to either Eco or Default (i.e. Disable Precision Boost Overdrive), depending on your comfort with losing CPU performance.
  3. The difference in performance between Default and Precision Boost Overdrive is very small.
1 hour ago, spiceygas said:
-snip-
Nice detail - Hopefully with BIOS updates things get better for this awesomely powerful chip
