Help, I can't seem to find the right laptop for me.
Solved by MaJelvin,
On recommendation by GeneXis_X, I chose the Gigabyte Aero 15 OLED SA.
It contains:
- An Intel i7-9750H (6 core CPU)
- An GeForce GTX 1660ti
- 16 GB RAM, expandable up to 64GB
- 256GB M.2 SSD ( Might even be PCIe speeds!) + extra M.2 slot for secondary storage
- 94 Wh Battery for 8.5 hours of office use when Optimus is activated
- 4K UHD AMOLED panel, 15 inch, X-rite Pantone Certified display
- Thunderbolt 3, DP 1.4 USB Type C 3.1, HDMI, 2 USB type A 3.1 gen 1, USB Type A 3.1 gen 2 and a Card Reader in the IO
- Slim and elegant design, only 2kg's heavy and <20mm thick
- Per-key RGB control for even more customization.
Everyting that's bold is what were specs that are pretty important to me or are very nice to have in a laptop and what finally made my choice
The exact model of my laptop is the Gigabyte Aero 15 OLED SA-7US5130SH
At the moment of writing this, the laptop is $1877, but I will probably buy it somewhere next year when the price has lowered even more.
Thanks all for your help, it really helped me make a good choice, and without you all I probably bought some high end 2500+ euro gaming laptop even though that's not even needed in my case.
