What "generated voltage"? They consume a TON of power, the resulting heat has to be disposed of on top of whatever it is you're cooling. Good luck with that.
https://linustechtips.com/topic/1099249-peltier-module-cooling/#findComment-12850153
I tried using a 40W Peliter on a 4 core AMD socket AM1 processor (very low power, low heat output). It "worked". The CPU didn't overheat but it didn't get any cooler than with the original heatsink. In fact I think it got hotter.
I then tried a 100W Peltier on a 3930K and a waterblock to cool the hot side. The CPU almost immediately started overheating. Barely into the BIOS.
It's not particularly viable. You need a peltier with about double the Wattage of the chip you're trying to cool then a cooler that can handle all of that.
https://linustechtips.com/topic/1099249-peltier-module-cooling/#findComment-12850156
When you heat up one side of a peltier module it will generate a voltage. :v
Im just not sure if you can power anything with it or the voltage isn't as stable as i thought.
https://linustechtips.com/topic/1099249-peltier-module-cooling/#findComment-12850173
That would be an thermoelectric generator, a peltier needs power to work. Same thing it seems, different name used :D
Having said that they need a big temperature difference to do anything. For example: CPU at 70-80 and ambient/cool side at 25 would give you 1,5v at 0,2A = 0.3W
https://linustechtips.com/topic/1099249-peltier-module-cooling/#findComment-12850176
You can use the Peltier as a generator. The Peltier Effect works both ways, im just not sure it will work like i would like it to. :/
https://linustechtips.com/topic/1099249-peltier-module-cooling/#findComment-12850189
Ok, the confusion lay in that you mentioned cooling, which requires you to put power into it. Using it as a generator means you get something out. The power generated will be tiny, and also you're going to have a seriously unhappy hot device next to it... it's not about voltage as much as total power, it just wont be much.
https://linustechtips.com/topic/1099249-peltier-module-cooling/#findComment-12850399
Well if you close the circuit it will draw current, which will absorb power (heat) from the cpu shroud. I guess it wouldn't really manage the power output (maybe with a super big heatsink). I just wanted to see if someone ever tried powering something in that way / cooling a cpu. :D
https://linustechtips.com/topic/1099249-peltier-module-cooling/#findComment-12850901
  • 2 months later...
Yes, I do it all the time. I cool my whole computer (CPU; GPU; PCI e) from the inside.
Remove the fans so I don't lose my cool.
Also, you hit the nail on the head. My heatsink is 180mm x 100mm x 30mm per 100W with 120mm 0.3A fan. Two of these units with a water jacket (between the peltier modules) sandwiched in-between with a digital thermostat for control. Modulate just one of the four peltier modules. All the rest of a liquid cooled system is the same, just no radiator. Unit goes on the floor.
Hot facing out, cold facing in!
The pictures include my thermostat, the setup behind my computer, and a basic system I use for a cooling vest.
I've been doing this for years, I use car antifreeze aluminum radiator formula with no problems.
https://linustechtips.com/topic/1099249-peltier-module-cooling/#findComment-13011604
All that work, to just achieve 44f lmfao
Join HWBot or OCN
#1 3DM Fire Strike Ultra score in the world.
#2 3DM Time Spy Extreme score in the world.
#3 3DM Fire Strike Extreme score in the world.
#7 3DM Sky Diver score in the world.
#8 3DM Fire Strike score in the world.
#12 3DM Time Spy score in the world.
All scores obtained with 8600K + 1x 1070Ti. Links in bio
https://linustechtips.com/topic/1099249-peltier-module-cooling/#findComment-13011614
