I'm the process of changing some components, notably moving from a GTX 1050 2GB to a RX 5700 and i was worrying that my (old) psu won't be enough anymore
  • Motherboard : AB350M-HDV
  • CPU : Ryzen 3 YD1200
  • RAM : Crucial Ballistix Sport LT ( 2x 8gb)
  • PSU: Antec HCG 520 EC
Considering the current upgrade and future ones, should i change it?
(This is the PSU)
Risultati immagini per antec 520w
https://linustechtips.com/topic/1099208-will-my-psu-be-enough/
As others have said, it will be more than enough power. I certainly agree with Kdawwg too though. It would be well worth upgrading the PSU soon to a more efficient one. If you can get a modular, it can make a world of difference in cooling, depending on what type of case you have.
Asus Prime X570-Pro, Ryzen 3800x (OC WIP), 16GB Corsair Vengeance RGB pro 3600, GTX 1080 (New card inc), Corsair H100i Pro RGB, Cooler Master H500P Mesh White Case
https://linustechtips.com/topic/1099208-will-my-psu-be-enough/#findComment-12849844
Nah, couple of PSU cables won't make a difference for temperatures.
https://linustechtips.com/topic/1099208-will-my-psu-be-enough/#findComment-12849848
I hadn't seen that video yet, that's pretty funny. I would never have expected those results. I had Micro ATX build I was working on a long time ago that I remember having good results from managing the cables in relation to thermals. Cases have come a long way since then though, and I wouldn't be surprised if that's no longer an issue though, based on this video. Thanks for sharing it :D
https://linustechtips.com/topic/1099208-will-my-psu-be-enough/#findComment-12849883
