Hi i am looking to put together a new pc but i have a comptability issue with my PSU does someone have a PSU that does meet the requirements for my motherboard?
My psu delivers 8 pin power but my motherboard has a 8 pin power and a 4 pin power connection.
I am looking to overclock.
https://linustechtips.com/topic/1099160-comptability-issue/
You can get an adapter like this or choose another PSU
https://www.ebay.co.uk/itm/ATX-4-Pin-Female-to-8-Pin-Male-EPS-Power-Supply-Cable-Adapter-Convertor-P4PM-12v/292070377561
Edited by LogicalDrm
If you want me to see your reply, please tag me @Faisal A
https://linustechtips.com/topic/1099160-comptability-issue/#findComment-12849359
Thats not what i ment my psu delivers 8 pin power but my motherboard has a 8 pin power and a 4 pin power connection
https://linustechtips.com/topic/1099160-comptability-issue/#findComment-12849363
Im pretty sure that some of those mobos that require both 8 pin and 4 pin actually just need the 8 pin to function correctly, and MAYBE ur able to overclock. Do some research first tho, as im not sure. I remember this from an old post on here like 1 month ago, as someone had a similar issue with not having enough cables for the mobo, but it worked out at the end.
https://linustechtips.com/topic/1099160-comptability-issue/#findComment-12849391
1 minute ago, arnekick said:
and if i overclock will it still be fine if i only connect the 8 pin power connecter
You will never exceed the minimum spec of a single 8 pin unless you have bucket of LN2 next to you and a lot of experience in extreme overclocking.
2 minutes ago, arnekick said:
How so?
Well. 970 evo doesnt make sense, the PSU does not need to cost that much. There are other mobos with similar featureset at a cheaper price
Among a few other optimizations
https://linustechtips.com/topic/1099160-comptability-issue/#findComment-12849399
Yeah it is clear in the manual for the mobo that it is optional and only really useful for extreme overclocking (LN2 or other subzero cooling) and even then there is no conclusive evidence that the 4 pin makes a difference.
https://linustechtips.com/topic/1099160-comptability-issue/#findComment-12849404
Just use the 8pin. The second 4pin is optional.
If you want an additional EPS12V connector then hit up Seasonic and buy another cable from them, or check out third parties that do cables. It needs to be designed to work with your specific model of PSU (Seasonic Prime Ultra Platinum).
Please no.
https://linustechtips.com/topic/1099160-comptability-issue/#findComment-12849406
19 minutes ago, arnekick said:
It only has an 8 pin and the motherboard needs 8 + 4
Motherboard doesn’t need both as far as I’m aware. Just the 8 pin will do for normal use (no ln2 OC /dry ice etc)
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1099160-comptability-issue/#findComment-12849407
Plug just the 8 pin, don't need the 4pin
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1099160-comptability-issue/#findComment-12849439
