7 minutes ago, Proprietary said:
do you know any ways of draining a system without a drain valve?
Find the lowest point in the loop, lean it over a bowl and unscrew it
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/1099003-leaking-custom-loop/#findComment-12848305
And after you drain, install a ball valve to your loop for future maintenance.
https://linustechtips.com/topic/1099003-leaking-custom-loop/#findComment-12848770
