RAM clearance issues - CPU cooling tips
Welcome comrades,
I am setting up a new build containing:
- Dark Base Pro 900 rev 2
- (4 * 16) 64 GB Trident Z Neo
- ASUS ROG STRIX X570-E GAMING
- R9 3900X (with occacionaly OC for some more demanding calculations)
- RTX 2080ti
Unfortunately I have no clue what CPU cooling may fit this setup. I have read dozens of review's, forums etc but I feel like I am roaming around emptiness :(
I want it to stay as cool as possible, therefore first call was Noctua NH-D15. However even with elevated vent it stand no chances. Same thing goes to DRP 4 and many others.
I have even considered AIO's but their performance is quite poor (from the results I've found compared to air coolers).
Last shot is NH-U12A. It seems to be acceptable but is there anything better around?
Have you got any recommendations? Please help.
Kind regards
https://linustechtips.com/topic/1098932-ram-clearance-issues-cpu-cooling-tips/
H60 should work and keep it relatively cool
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
42U Server Rack: ISP Modem + UDM-SE + APC 3kVA UPS + 3x Dell Precision 5820 + TBD
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
why? how?
nice joke there
Desktop benching:
According to this site:
https://noctua.at/en/nh-d15/specification
it should be possible because I would be able to lift vent up to about 28 mm (so the clips still have something to catch) I guess.
However I've found a thread where 2 people were claiming that heat spreaders / pipes may touch your RAM (or there is like 2mm space between them) and that's where i've started to worry.
the dark rock pro 4 clears Trident Z
Primary PC:
PSU tier list
How many watts do I need?
Nah it's fine. 64mm RAM clearance for the heatsink is enough for all but the double height 32GB sticks. As for the fan, the fan clips allow the fan to go way up so it's not a problem for the only 44mm Trident Z.
Desktop benching:
I have the NH-U12A, pretty good cooler. You could could look into the NH-D15S which has better ram clearance that the regular NH-D15, it only uses one fan but still performs very well. the "S" has a different heatsink design.
9900K  / Noctua NH-D15S / Z390 Aorus Master / 32GB DDR4 Vengeance Pro 3200Mhz / eVGA 2080 Ti Black Ed / Morpheus II Core / Meshify C / LG 27UK650-W / PS4 Pro / XBox One X
The case is huge and supports coolers up to 185mm. The NH-D15 would fit just fine.
Here's an example: https://pcpartpicker.com/b/NzgwrH
