For some reason i am having severe issues when trying to install windows 10 on a usb as whenever it get to 50% on the second step it gives an error and said it had a problem running the tool, does anyone know what this is/ has a fix for it ???
CPU: Amd Ryzen 3400g
COOLER: Be Quite Dark Rock Pro 4
MOBO: Aorus x570 elite
RAM: 2x8 Corsair Vengence 3200 MHz
SSD: Samsung 970 Evo Plus 500GB
GPU: Powercolour Red Devil RX570 4GB
PSU: Corsair RM750x 80+ Gold
CASE: Coolermaster H500p Mesh
https://linustechtips.com/topic/1098215-help/
maybe the usb drive isnt formatted correctly
Quote
  1. Open Disk Management: Right-click on Start and choose Disk Management.
  2. Format the partition: Right-click the USB drive partition and choose Format. Select the FAT32 file system to be able to boot either BIOS-based or UEFI-based PCs.
  3. Set the partition as active: Right-click the USB drive partition and click Mark Partition as Active.
https://docs.microsoft.com/en-us/windows-hardware/manufacture/desktop/install-windows-from-a-usb-flash-drive
https://linustechtips.com/topic/1098215-help/#findComment-12841817
Try recreating the installation USB
Run memtest
https://linustechtips.com/topic/1098215-help/#findComment-12841819
When I was installing the 32 and 64 bit versions of windows installs on my USB, it gave a similar error. Try installing 64 bit only, or if you already are, try installing 64 and 32 bit
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1098215-help/#findComment-12841820
4 minutes ago, spartaman64 said:
About to try that
ok but will it affect it in any way
https://linustechtips.com/topic/1098215-help/#findComment-12841835
No
Primary PC:
PSU tier list
https://linustechtips.com/topic/1098215-help/#findComment-12841854
1 hour ago, Fasauceome said:
No
It didn't work
https://linustechtips.com/topic/1098215-help/#findComment-12842050
