rgb light strip wifi controller
Go to solution Solved by DejaVoodoo,
Should be able to...I have used multiple remotes on different receivers.
I am planning to buy this strip: https://www.amazon.com/dp/B00JF0589E/
in addition with this controller so I can use a remote as well as IFTTT: https://www.amazon.com/dp/B07V2CB6GG
this will give me the perfect setup: RGB + CW (cool white), IFTTT, remote control so I dont have to rely on a phone all the time, decent price.
my question is: will I be able to use any remote (from either link above) to control the lights? they are both from supernight so would they be compatible? the remote on the 1st link is better but the controller from the 2nd link is better. I want both.
https://linustechtips.com/topic/1097913-rgb-light-strip-wifi-controller/
