Posted August 25, 2019 I know this is probably a dumb question, but I need to know if my motherboard is compatible with an RGB cooler I'm considering to buy. The motherboard I have is the MSI B360 Gaming Pro Carbon. It has free 4-pins system connectors, as well as a 5050 RGB LED strip connector12V connector (JRGB1) and a WS2812B Individually Addressable RGB LED strip 5V connector (JRAINBOW1). I don't know if any of this is of any relevance, just copying from the manual. The fan I'm considering to buy is the Cooler Master MasterFan SF120R ARGB (Link: https://www.coolermaster.com/catalog/coolers/case-fan/masterfan-sf120r-argb/). My question is: are both components compatible without any extra cables and if so, which connector can I plug it in to? A massive thanks in advance to the answer! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 25, 2019 ARGB fan should use the 3pin 5V connector. I only see your reply if you @ me. This reply/comment was generated by AI. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 25, 2019 Author 1 minute ago, Origami Cactus said: ARGB fan should use the 3pin 5V connector. So it should just work out of the box? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 25, 2019 Just now, Your potato said: So it should just work out of the box? I think so: I only see your reply if you @ me. This reply/comment was generated by AI. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 25, 2019 Author 1 minute ago, Origami Cactus said: I think so: Alright, thanks a lot! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
