So I wanted to find out about this and couldn't find anything on the internet. I currently have an ASUS ROG STRIX GTX 1070 and EVGA GTX 980 Ti Hybrid on my hands and I'm wondering if I will be able to run them in SLI and make it work. I'm just concerned about whether they'll work together or not and as far as I know the 900 series isn't compatible with FreeSync but will I be able to use my G-Sync compatible monitor if I connect it to the 1070? I have a Gigabyte z390 Gaming X mobo (not sure if it supports SLI either)
https://linustechtips.com/topic/1097216-980-ti-1070-in-sli/
You can not since SLI is only supported to matching GPUs, thereafter you need either another 980 Ti or another 1070.
Either ways SLI is a dying technology you shouldn't bother with nowadays.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1097216-980-ti-1070-in-sli/#findComment-12833859
You mention Gsync and Freesync side by side here, but it's important to note they're different. Gsync would work with 900 series cards already, so if you have a Gsync monitor, you wouldn't need to add a 1070 to make it work. Freesync on the other hand would require a 10 series card.
Primary PC:
https://linustechtips.com/topic/1097216-980-ti-1070-in-sli/#findComment-12833866
There was a software hack that allows two dissimilar or unsupported nvidia GPUs to run SLI, but from what I saw at the time it was a world of pain to set up (disable driver signing in Windows and other steps). Just save your time and sanity and stick to a single card, or get a faster one if you really need it.
https://linustechtips.com/topic/1097216-980-ti-1070-in-sli/#findComment-12833867
