PHP error, please help ( SOLVED )
Solved by BakaPetra,
I fixed it, my dumbass forgot to put an if before the foreach (str_get_html($table)->find('tr') as $tr) line so if the $table variable is empty the function returns FALSE...
Fix line: if ($table != null ){
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
