Best cooler for Ryzen 9 3900x
Wacofopus
Hey
I got a Ryzen 9 3900x with the stock cooler. However I've noticed the temperatures can get a bit high. Which is why I've done some googling for a good air cooler (Not a fan of Water/Liquid/etc cooling)
I've found a few coolers, but was wondering if they're better than stock cooler or which one of these are best:
Noctua NH-D14
Noctua NH-D15S
Noctua NH-U14A
BQ! Dark rock TF
Scythe Mugen Rev. B
Or any other suggestions?
(Any cooler over 161mm is no option)
D15S has the best performance and noise, but what are the prices? What board are you using?
Desktop benching:
Price can be up to 115$, board is X570 GAMING PLUS
Noctua NH-U12A
Be Quiet! Dark Rock 4 (non-pro)
yeah but it's 165mm...
Quote and/or tag people using @ otherwise they don't get notified of your response!
The HUMBLE Computer:
AMD Ryzen 7 3700X • Noctua NH-U12A • ASUS STRIX X570-F • Corsair Vengeance LPX 32GB (2x16GB) DDR4 3200MHz CL16 • GIGABYTE Nvidia GTX1080 G1 • FRACTAL DESIGN Define C w/ blue Meshify C front • Corsair RM750x (2018) • OS: Kingston KC2000 1TB GAMES: Intel 660p 1TB DATA: Seagate Desktop 2TB • Acer Predator X34P 34" 3440x1440p 120 Hz IPS curved Ultrawide • Corsair STRAFE RGB Cherry MX Brown • Logitech G502 HERO / Logitech MX Master 3
Notebook:  HP Spectre x360 13" late 2018
Core i7 8550U • 16GB DDR3 RAM • 512GB NVMe SSD • 13" 1920x1080p 120 Hz IPS touchscreen • dual Thunderbolt 3
4 minutes ago, Wacofopus said:
X570 GAMING PLUS
Swap for a better board.
Say Gigabyte x570 Auros elite.
Can't return my current one anymore.
I don't see how the board can cause relatively high temperatures under some load. As the temps stay under 85°C (I can hear the fan at full speed)
I just want it to run as cool as possible
Well...... The VRM on the x570 gaming plus isnt brilliant. It wont make the CPU hotter, but its not great.
I see, might be something for the near future then. Can't do that at this moment.
I can forsee the power delivery on this board to run quite hot since 3900x draws power like the 2700x, and that nearly cooked the X470 Gaming Plus with a slightly worse VRM.You can compensate that with downdrafts like the TF or Noctua NH-L12S
Desktop benching:
I got an X470 motherboard on our other PC, could maybe swap them around (Since this isn't a pc with heavy usage). The other one is a Asus ROG STRIX X470-I Gaming
Would this one have the same issue and need downdraft?
same issue imo. Better components, but worse cooling.
Desktop benching:
Alright, guess I'll stick with this. The Dark Rock TF provides better cooling than stock cooler I hope? Stock cooler is quite noisy from time to time too.
Yes its better than stock. It will also blow air on the motherboard vrm heatsinks so its good for that too.
You're thinking of the NH-D15. In either case, both the NH-D15 / S heatsinks are only 160mm. With the NH-D15S, the only fan present is the middle fan which can be entirely lowered into the heatsink.
