What would be the best software to check how much power my PSU is using? I have a Corsair AX860, and don't have any instrument to check the power draw direct from the wall socket. By checking an online calculator, it says my system uses about 607 Watts, but it is not considering that I have a Xonar Essence STX sound card, and that that both CPU and GPU are overclocked. I know a software will never do the job 100% accurate, but it will give me a rough idea nonetheless.
Edit*
I checked this link (https://outervision.com/power-supply-calculator) and that's what I got. This is quite close to the limits of my PSU.
Load Wattage:749 W
Recommended UPS rating:1440 VA
Recommended PSU Wattage:799 W
For water cooler, they didn't have the Corsair H150i Pro, so I went selected the h115i.
https://linustechtips.com/topic/1095148-psu-power-draw-check-software/
No software will tell you.
Use a power meter : https://www.amazon.com/s?k=power+meter&ref=nb_sb_noss_2
Outervision is shit in general.. say the specs and I'll ballpark your computer's power consumption
Quote
That's like 10-15w at most... nothing to stress about.
  • CPU
    Intel i9 9900k @5.0ghz all cores, 1.27v, stock cache speed
  • Motherboard
    ASUS Z390-E Strix
  • RAM
    Corsair Vengeance RGB Pro 32GB (4x8 sticks) 3200 CL16 1.35v XMP
  • GPU
    ASUS RTX 2080 Ti Strix (ROG-STRIX-RTX2080TI-O11G-GAMING). Afterburner settings picture attached bellow
  • Case
    Phanteks Evolv-X
  • Storage
    Samsung Evo 970 Plus 1Tb
  • PSU
    Corsair AX860 Platinum
  • Display(s)
    Acer Predator X34P
  • Cooling
    Corsair H150i Pro
    3x 120 Corsair LL Fans (radiator mount on top on push config, exhaust)
    1x 140 Corsair LL fan (back exhaust)
    3x Phanteks 140 fans (frontal intake)
  • Keyboard
    Ducky One 2 Mini - Cherry MX Blue
  • Mouse
    Logitech G Pro Wireless + G840 Mousepad
  • Sound
    ASUS Xonar Essence STX
    Sennheiser HD 700 headphone
    Audioengine A2+ speakers
    Blue Yeti Nano microphone
  • Operating System
    Windows 10 Pro
    I put all settings I think could be relevant for you.
9900k - around 100w when gaming (because most games don't use all cores at 100%), ~170w at stock and 200w when oc using all cores, up to 250w under torture tests (prime95 and heavy avx)
See review here where they run 9900k at 5ghz :
https://www.tomshardware.com/reviews/intel-core-i9-9900k-9th-gen-cpu,5847-11.html
https://www.anandtech.com/show/13400/intel-9th-gen-core-i9-9900k-i7-9700k-i5-9600k-review/22
30-50w for motherboard (chipset, onboard sound, lan, wifi)
10w for ram - 2-3 watts per stick
5w for ssd
maybe 10w for the pump in the aio
2-3 w for each fan , add 1w for rgb per fan
ASUS RTX 2080 Ti Strix ,,,, ~270w stock, maybe 300-330w when overclocked ... see https://www.techpowerup.com/review/asus-geforce-rtx-2080-ti-strix-oc/31.html
kb, mouse ... 1-2w each
5w for ssd
Thank you for being very detailed. I'm still on the safe side, so I shouldn't worry about getting another PSU (this one I got back in 2014).
