Hi, I'm going to attempt to build my first PC and I want to make sure that when I mess it up I can't blame the hardware. I'm very new to PC parts and stuff so there's bound to be a few errors. Here are the parts:
Case: NZXT H500
CPU: Intel Core i7 9700k
Cooler: Corsair H115i PRO RGB water cooling
GPU: MSI NVIDIA GeForce GTX 1060 GAMING X 6 GB  GDDR4 Memory PCI Express 3.0
Power Supply: Corsair CP-9020131-UK TXM Series 750W TX750M ATX/EPS Semi Modular 80 PLUS Gold
Storage: Samsung SSD 860 QVO 1TB
Memory: Corsair CMK16GX4M2B3200C16 Vengeance LPX 16 GB (2 x 8GB) DDR4 3200MHz C16 XMP 2.0
Motherboard:  MSI  MPG Z390 GAMING PRO CARBON (Socket 1151/Z390/DDR4/S-ATA 600/ATX)
Optical Drive: External CD DVD Drive, Vlio USB 3. portable slim CD DVD +/-RW Drive player burner, writer, reader
Once again, sorry if there are any errors. If you need more info please ask me. Please tell me if I should cut back, price wise, on some parts, what to replace them with and then what I could use that money with to upgrade/change. I'm trying to keep around the same price as it is, but I don't mind pushing it a bit. If you have any questions please feel free to ask. Thanks.
https://linustechtips.com/topic/1095098-do-these-components-work/
Depending on your budget, try and get a better GPU. I feel like the 1060 6GB will bottleneck your CPU. Try for a 1080 or 2070 super
CPU | Ryzen 7 3700x        GPU | MSI Gaming X Trio RTX 2070 Super       Motherboard | MSI MPG X570 Gaming Edge Wifi
Cooler | NZXT Kraken x62       Memory | 16GB (2x8GB) GSkill TridentZ RGB @3200MHz       Case | Phanteks Eclipse P400S TGE
Storage | 2TB Seagate Barracude + 500GB Samsung 970 Evo Plus NVMe SSD       Power Supply | 750W Seasonic Focus Plus Gold
You can get a much better system for either the same price or cheaper. Where are you from and what's your budget? Do you have a display you intend to use?
Ive rebuilt the system for a similar price (UK). The only think they you might want to add is a wireless card.
Ryzen 5 3600
Gigabyte Aorus X570 Elite
Cooler Master ML240L
Corsair Vengeance LPX 16GB (2x8GB) @3600MHz
Samsung 970 Evo Plus SSD 250GB
2TB Seagate Barracude Compute HDD
MSI Gaming X RTX 2060 Super
Corsair TXM Gold 750 W
Yes, you are sacrificing cores. But, you are gaining 4 more threads (Due to SMT on Ryzen CPUs and not on 9700k) and a very improved GPU
Case: NZXT H500
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (£188.97 @ CCL Computers)
Motherboard: MSI B450 TOMAHAWK ATX AM4 Motherboard  (£106.99 @ Amazon UK)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 Memory  (£94.99 @ Corsair UK)
Storage: Crucial MX500 500 GB 2.5" Solid State Drive  (£61.09 @ Amazon UK)
Storage: Seagate Barracuda Computer 2 TB 3.5" 7200RPM Internal Hard Drive  (£53.99 @ CCL Computers)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  (£450.79 @ Overclockers.co.uk)
Case: Fractal Design Meshify C ATX Mid Tower Case  (£89.99 @ PC World)
Power Supply: be quiet! Pure Power 11 CM 600 W 80+ Gold Certified Semi-modular ATX Power Supply  (£73.98 @ Aria PC)
Total: £1120.79
Generated by PCPartPicker 2019-08-17 21:53 BST+0100
Suggest getting something along the lines of this instead.
2 hours ago, Elee said:
I'm from the UK and my budget is £1200
I'll recommend something like this instead...
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (£316.98 @ Aria PC)
Motherboard: MSI B450-A PRO ATX AM4 Motherboard  (£79.99 @ CCL Computers) Supports BIOS flashback.
Memory: Kingston HyperX Predator 16 GB (2 x 8 GB) DDR4-3200 Memory  (£81.58 @ CCL Computers)
Storage: Intel 660p Series 512 GB M.2-2280 NVME Solid State Drive  (£56.10 @ CCL Computers)
Storage: Toshiba P300 3 TB 3.5" 7200RPM Internal Hard Drive  (£65.09 @ CCL Computers)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  (£423.31 @ Amazon UK)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (£64.97 @ Laptops Direct)
Total: £1178.01
Generated by PCPartPicker 2019-08-18 12:28 BST+0100
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
Total: £1178.01
Thanks,
Am I able to switch the graphics card to a ZOTAC GPU NV RTX2060 AMP 6G Fan?
Edited by Elee
