Prime 95 and Aida64 for the CPU and memory. MSI Kombustor and Unegine Superposition for the GPU.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1094459-stress-test-for-cpu/#findComment-12811324
4 minutes ago, Mustangmatt215 said:
If I use prime 95 is there any settings to just be able to stress test cpu only
The one for Maximum Heat I believe it's the top one called FPU will stress test the CPU at 100% on all cores so that you can see how hot it will get under maximum load, make sure you have a temp monitoring software like HWMonitor open so you can monitor the usage and temps. Aida 64 is better for testing overclocks and such though.
https://linustechtips.com/topic/1094459-stress-test-for-cpu/#findComment-12811350
31 minutes ago, TheGlenlivet said:
P95 is a CPU only test.
It has multiple tests, one which only tests CPU and two that test the CPU, Memory Controller, and Ram for max power draw and what not.
https://linustechtips.com/topic/1094459-stress-test-for-cpu/#findComment-12811353
whats a good website to get aidi64
They have a free trial on their website, if you mean like getting it for free permanently I have no clue.
https://linustechtips.com/topic/1094459-stress-test-for-cpu/#findComment-12811381
i enjoy using Passmark as the results for each component it tests get compared to the exact components average for every test done by anyone , even down to the exact part numbers.
it's a good program to use to make sure your machine is performing on par with what each component should be running at.
https://linustechtips.com/topic/1094459-stress-test-for-cpu/#findComment-12811387
I use Furmark, they have a CPU burn in as well as GPU.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1094459-stress-test-for-cpu/#findComment-12811389
1 minute ago, TheGlenlivet said:
CPU, Memory controller and Ram, but not GPU and not "whole system".  That's my point.
Ahh I haven't used prime95 to often but you'd think with the Blend Test saying (tests a bit of everything) and then Max Power consumption would be the whole system.
https://linustechtips.com/topic/1094459-stress-test-for-cpu/#findComment-12811401
Nope.  The blend (all of the above) option is still only ram controller and CPU.  Furmark or something like that would be a GPU stress test.
In fact, you can run p95 from a terminal without even having a GUI up.  Its all CPU.
https://linustechtips.com/topic/1094459-stress-test-for-cpu/#findComment-12811425
I know what furmark is, I just haven't used prime95 a lot. I mainly use Aida64 only time I use Prime95 is when I need to see if a CPU is thermal throttling.
https://linustechtips.com/topic/1094459-stress-test-for-cpu/#findComment-12811436
I got ya, I just don't want the OP running P95 for an hour and wondering why his GPU is at 32 degrees....
https://linustechtips.com/topic/1094459-stress-test-for-cpu/#findComment-12811457
Yeah I feel you.
https://linustechtips.com/topic/1094459-stress-test-for-cpu/#findComment-12811473
