mapping shortcut to key
Go to solution Solved by badreg,
See here:
https://www.autohotkey.com/boards/viewtopic.php?t=48275
Basically, you redirect the F22 (or Ctrl-Shift-F22) to send a right-click.
Print screen redirect:
https://autohotkey.com/board/topic/95968-how-to-make-printscreen-key-controlf8/
I have a record button on my laptop (screen recording start/stop).
I dont use that feature. so I wanted to re-map it to a right click which i really miss from my old laptop.
i used an AHK script to find out that when i press the record button, it does the following keystrokes in this order:
  1. F22
  2. Ctrl + Shift + F22
  3. Alt + Lwin + r
is it possible to map this to the right click button?
EDIT: I dont use the prtsc (print screen) button either. can that be remapped?
https://linustechtips.com/topic/1094392-mapping-shortcut-to-key/
See here:
