PC not booting after failed overclock
Go to solution Solved by SpookyCitrus,
5 minutes ago, SCastanedaMunoz said:
CPU: AMD Ryzen 7 3700x
2. Removed Graphics Card since it is not an essential item for the pc to boot
The 3700x does not have integrated graphics, a GPU is 100% essential for it to boot or display anything.
Attempted to get my brother into overclocking his PC. I have done it on the past, but while testing multiple setups the PC stopped booting.
Here are the specs:
GPU: NVIDIA Geforce RTX 2070
MOBO: Gygabyte x470 Aorus Ultra
RAM: Ballixtics DDR4 2400 Mhz (Base Speed)
SSD: ADATA SU630
The main problem is that the PC turns on, but there's never signal of it getting into the BIOS or the OS. This is what I have attempted so far:
1. Clear the BIOS - By using the CLR_CMOS jumper and Removing the BIOS Battery.
3. Removed secondary RAM Stick
Here is the MOBO Manual Aorus x470 Ultra Gaming
When attempting to boot the machine the Status LEDs go all the way up to boot, but then it stays there. Nothing happens.
(Status LEDs) information found in MOBO manual page 21
Any recomendations?
https://linustechtips.com/topic/1093989-pc-not-booting-after-failed-overclock/
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
Here are the specs:
SSD: ADATA SU630
Any recomendations?
Actually, your graphics card IS essential for the PC to boot. I don't believe a Ryzen 7 3700x has an igpu.
Place GPU back in, remove all cables going into the tower including monitor. Clear cmos then hold power button for 30 seconds to discharge any remaining power. Plug everything back in, start PC and boot directly into bios. From here find "Load Optimized Defaults", enable and reboot PC. This will remove any overclock settings that were applied. If this does not work then you may have damaged the board.
Out of curiosity what was the last cpu voltage you applied?
Intel Core i7 9700F / Cooler Master 212 Evo / GeForce GTX 1660 SUPER / 16 GB G.SKILL RAM @ 2666MHz / GA-B365M-DS3H / EVGA 500w PSU
HP Pavilion Gaming 15 / Ryzen 5 4600H / GeForce GTX 1050 / 8 GB @ 3200MHz
Yeah this is the standard procedure I was following to reset the board. At the end it seems it was booting correctly; however no video signal, since I removed the GPU. It's very likely it might already be booting properly, just need to double check the video signal. CPU Voltage was still around default levels for Ryzen 7 3700x. This happened when we were starting to modify actual values.
