I really need help, so basically this pc gaming clan asked me if i wanted to join, but the problem is that the games that they play are extremely similar to the one that they scouted me from, but my pc doesn't have high enough specs. If anyone could make a the best pc build for around $800 I would greatly appreciate it. Thanks so much ?. (The game is a triple A title, and i need it to be able to run the best it can at the higher settings)
https://linustechtips.com/topic/1093440-need-help/
what game is it exactly?
Desktop benching:
https://linustechtips.com/topic/1093440-need-help/#findComment-12802926
Game, Monitor and Country are generally needed.
https://linustechtips.com/topic/1093440-need-help/#findComment-12802948
it is battlefield v
Battlefield V
Acer SB220Q (if required i can pay a extra $150 for a new monitor)
US
https://linustechtips.com/topic/1093440-need-help/#findComment-12802959
On 8/12/2019 at 8:38 PM, HUExGxRECTION said:
I currently use a Mac Mini from like late 2012 so i need complete build ?
Ah. That makes some sense.
Would need to track down a Win10 license through one of the resellers for cheap. Could drop some prices in a few places. Next GPU upgrade is 70USD more.
https://linustechtips.com/topic/1093440-need-help/#findComment-12802994
2 questions. 1 would i need to get a new monitor, and 2 what would the next gnu upgrade be? the Ti?
https://linustechtips.com/topic/1093440-need-help/#findComment-12803024
On 8/12/2019 at 8:49 PM, Thejbcrazy said:
Perhaps your best bet it going used... GPU alone going to take the majority of you budget. If you buy new
Used GPU would be the most cost effective, but it's also hard suggest that move to people if they're new to the space.
Technically, the next GPU is the 2060, though I'd recommend the AMD RX 5700 if you're a BFV player since that game loves Navi a lot.
You don't need a new monitor until you get really committed to it. So it could wait.
If you're comfortable with used GPUs, a 1070 under 250USD would be a good purchase.
https://linustechtips.com/topic/1093440-need-help/#findComment-12803026
thanks for the help!!
https://linustechtips.com/topic/1093440-need-help/#findComment-12803043
I'll recommend something like this instead...
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($132.79 @ Amazon)
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard  ($79.78 @ OutletPC)
Memory: Team Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($67.89 @ OutletPC)
Storage: Sabrent Rocket 512 GB M.2-2280 NVME Solid State Drive  ($59.98 @ Amazon)
Video Card: Sapphire Radeon RX VEGA 56 8 GB PULSE Video Card  ($309.99 @ Amazon)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($44.99 @ B&H)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply  ($74.99 @ Newegg)
Total: $770.41
Generated by PCPartPicker 2019-08-12 22:33 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1093440-need-help/#findComment-12803106
