Does removing cables from my monitor make the ports more susceptible to damage? I ask this because I have made a desk for working and just use my normal coffee table on my couch for gaming.
Acer Predator Helios 500
8th Gen Intel Core i7 8750H
Nvidia Geforce GTX 1070 8GB (Mobile)
16GB DDR4 SDRAM
1TB Hard Drive
256 GB Solid State Drive
Processor Speed 2.20 GHz
Wireless LAN Standard IEEE 802.11ac
Screen Resolution 1920 × 1080
Operating System: Windows 10 Home
https://linustechtips.com/topic/1092066-cable-removal/
Yes. its mechanical wearing. Everytime something is plugged in or out, there is friction. Also with DVI you have possibility of harming pins when plugging it in. So avoid if possible.
Having ports without cable plugged in doesn't matter.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1092066-cable-removal/#findComment-12795485
If ur going to be constantly removing USB cables, consider getting 'small' USB extension cables so that if/when they wear out u can just replace them. Leave the extensions plugged in all the time and just unplug from them instead of the monitor.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1092066-cable-removal/#findComment-12796175
Using short extensions will also make reaching ports hidden on the back of something easier to access.
Jeannie
As long as anyone is oppressed, no one will be safe and free.
One has to be proactive, not reactive, to ensure the safety of one's data so backup your data! And RAID is NOT a backup!
https://linustechtips.com/topic/1092066-cable-removal/#findComment-12796212
