BOTTLENECK ISSUE
Solved by RasmusDC,
1 hour ago, FlappyBoobs said:That CPU is a bottle neck even for a 1060.
bullshit...
i have a 3570k 4790k and my 8700k, taking a 970GTX which is nearly the same as the 1060, actually faster than a 1060 3GB, the performance increments are small, they are there, but in 1080p it does not matter.
a 1080 on a 3570 will make everything run easily... YES you will loose some frames compared to a faster CPU in some games.. but it is still a nice pc.
