Noisy fan bearing, PC shutdown after a while
Solved by LogicalDrm,
6 hours ago, pwh123 said:
I can't find out which fan is/was loud as it's not loud anymore (bearing gave up maybe) or it doesn't have the chance to be loud because the PC shuts down before it would get noisy.
That's most likely dying PSU, if you don't have any other symptoms (loading issues, sluggishness etc.).
6 hours ago, pwh123 said:Again, I can't moniter the fans while one of them is loud, unfortunately.
Why not? This would mean running stress test or benchmark. Which are usually windowed anyway. Those would also be good way of pinpointing when shutdown happens (under load vs random).
