Hello, do you think i should have top fan as exhaust or intake to cool vrms?  Right Now i have front push pull intake on rad, And other front fan as intake, top as exhaust. And i got good results in Aida 64. CPU is i9 9900k. Gpu 1080ti fe blower. Also do you think its worth to add 2x 80mm fan at back ?Thanks
https://linustechtips.com/topic/1091784-airflow-question/
For a solid airflow path, I think double fans exhausting out the back would do nicely, or just transition your current single fan to the back to see if you get an improvement to either noise levels or temps
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1091784-airflow-question/#findComment-12790513
Thank you. Also may I ask about gpu. As there is restricted place for gpu to breath -> Now I have GTX 1080ti FE ( blower) it has 7cm to breath in my case ( Corsair Air 240). I could also have GTX 1080ti ASUS STRIX, which is beafier so there would be even less space. Do you think blower is better choice in these conditions ? thx
https://linustechtips.com/topic/1091784-airflow-question/#findComment-12790560
The strix would overall be better. Not only do you have little space to breathe, but some of the air coming in for the GPU to breathe comes straight off the CPU radiator so it's already heated. A strix has one of the best coolers out there, I say go for it.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1091784-airflow-question/#findComment-12790563
What you have currently seems fine. What are your temps?
https://linustechtips.com/topic/1091784-airflow-question/#findComment-12791279
5 minutes ago, name66 said:
Here are temp from 32 mins of Aida64
Your temps aren't particularly low but are perfectly fine. As long as the noise levels aren't too high, there's no need to get new fans.
https://linustechtips.com/topic/1091784-airflow-question/#findComment-12791311
Okay thank you :) These temps are with Corsair h80i quiet profile, so I could change if needed as well.
https://linustechtips.com/topic/1091784-airflow-question/#findComment-12791316
