Ducky one 2 TKL Brightness issue
Telleron
I am very happy with my Ducky keyboard. But ever since I installed the software from the Ducky website i've been having some issues with it.
The brightness isn't as bright as it used to be and the FN keys don't light up/ flicker when I press it. I have tried pressing the fn+up key to adjust the brightness but nothing really works.
I hope someone can help me out with this issue
Thanks
Does it needs a software installation?
Doesn't it has onboard RGB controls via hotkeys, so no need any software just like the One 2 Mini?
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
  • 2 months later...
hi i had the same problem.how do you fix it??
You might want to factory reset the keyboard. This can be done by holding the right and left windows keys.
